eos m10 vs eos m100
Started Dec 4, 2018 | Discussions
dpreviewreader80 Regular Member • Posts: 176
eos m10 vs eos m100
i can get m10 for 280 eur and m100 for 390 eur both new,  what should I buy, I read that AF in m100 is much better?
Canon EOS M10 Canon EOS M100 Leica M10
thunder storm Forum Pro • Posts: 10,139
Re: eos m10 vs eos m100
Yes, the M100 has dpaf.
I don't know where you want to order your M100, but in the Netherlands it is body only available for 280 euro - 40 euro cashback = 240 euro in the colors grey and white.
Add a 22mm f/2.0 from eglobal central for 150 euro or less, and you have a nice combination for a very good price.
 thunder storm's gear list:thunder storm's gear list
Canon EOS 6D Canon EOS M6 II Canon EOS R5 Sony a7 IV Canon EF-S 15-85mm f/3.5-5.6 IS USM +24 more
OP dpreviewreader80 Regular Member • Posts: 176
you mean 280 eur with kit lens 15-45?
Ben Herrmann
Ben Herrmann Forum Pro • Posts: 21,163
I have to say that...
...I seemingly had more fun with the M10 (which I've sold) as compared to the M100.  And why?  Mainly due to the metering scenario.  With the M100, even though you select evaluative metering, the AF box still behaves as if you had spot metering selected.  Rather than just meter the entire scene, the metering tends to be influenced right where you place the AF box - which drives me batty.  Sure, I shoot in RAW mode so I can adjust levers to bring up or tone down hi-lights and/or shadows - but evaluative metering should be able to evaluate the entire scene - not the area by the AF point.
The previous M10 wasn't as picky in this regard.  All of the newer EOS M models have this issue.  With other brand cameras there are options (some of them at least) where you have the choice of choosing where the evaluative metering will take place - whether of the entire scene, or where the AF points are.  Not so with the M.
So I have to say that I've had more fun with the M10 and it's capable of generating some superb IQ levels.  But I'm also enjoying the use of my M100 - just not the metering aspect of using it.
Life can be good - if you allow it!
Bernd ("Ben") Herrmann
Fuquay Varina, North Carolina USA
 Ben Herrmann's gear list:Ben Herrmann's gear list
Canon EOS M Fujifilm X-E2S Fujifilm X-T2 Fujifilm X-T20 Canon EOS M6 +4 more
Re: I have to say that...
thanks for that
No, that is body only.
For my shooting this metering is a nice thing to have, but i agree you should be able to turn it off.
well i get a lens 15-45 for this price so your price isn't that nice anymore
I am happy for you!
Alastair Norcross
Alastair Norcross Veteran Member • Posts: 9,874
With every Canon digital ILC I've owned (300D, 20D, 50D, 7D, 7DII, M, M6) evaluative metering has behaved this way. If an AF mode using single points is selected, the metering is biased towards the selected AF point (though not as much as spot metering). If I want the metering to take more account of the whole scene, I switch to center-weighted average metering mode. Is this not a possibility on the M100? On my M6, I have four metering options: evaluative, partial, spot, and center-weighted average. The difference between partial and spot is the size of the area in the center used for metering (spot uses a smaller circle in the center). Another way to stop the metering being biased towards the AF point is to switch to MF and lock the metering, then switch back. In any case, I find that the metering behavior of biasing towards the AF point is very useful in most cases. I wouldn't want Canon to change that. If you don't like that, just use center-weighted average metering (if it's available).
As the length of a thread approaches 150, the probability that someone will make the obvious "it's not the camera, it's the photographer" remark approaches 1.
Alastair
http://anorcross.smugmug.com
Equipment in profile
 Alastair Norcross's gear list:Alastair Norcross's gear list
Canon G7 X II Canon EOS M6 II Canon EOS R7 Canon EOS R6 Mark II Canon RF 35mm F1.8 IS STM Macro +24 more
Rock and Rollei Senior Member • Posts: 2,899
Yeah, same options on the M100, accessible with the Quick Menu.
 Rock and Rollei's gear list:Rock and Rollei's gear list
Canon EOS 5DS R Canon EOS 5D Mark IV Canon EOS R Canon EOS M6 II Canon EF 50mm f/1.2L USM +29 more
