gipper51
Playing around with my PC today, and ran the Puget Systems 2018 Photoshop benchmark with some different settings. Interestingly enough, Photoshop CC 2018 is running faster with hyperthreading turned off! This included the benchmark scores and also a test of exporting a batch of RAW files to JPG. I"m surprised at the export times as it uses all cores when doing so, I'd have thought HT would help here...but it doesn't.
My specs that matter for the test:
8700K overclocked to 4.8Ghz
32GB DDR3200
960 EVO boot drive
1080 GTX
My export test was exporting 90 RAW files from a 7D2 to JPG in ACR. Times to export were as follows.
4.8Ghz With HT: 2:08
4.8Ghz Without HT: 1:58
5.1Ghz Without HT: 1:51
The CPU temps dropped a few degrees without HT, so I cranked it up to 5.1Ghz and tested it. It can run a bit faster with HT off. 128 seconds vs 111 seconds for the export. That's 15% faster.
These were my Puget benchmarks with those settings. Starting at 4.8 with HT, then no HT, then 5.1Ghz with no HT. Overall score went from 1003 to 1044. The temps were monitored in RealTempGT. Cores never exceeded 67C during the test.
4.8 Ghz with hyperthreading on
4.8 Ghz with hyperthreading off
5.1 Ghz with hyperthreading off
I guess I'll leave hyperthreading off from now on. Photoshop is the only program I use that really uses the CPU horsepower, and if it's running faster without HT....
Damn. I know PS is not a program that utilizes multiple threads well, but I didn't expect there to be a negative performance hit with having HT on.
My site:
32GB DDR3200
960 EVO boot drive
1080 GTX
My site:
