Lumix G 12-35mm f/2.8 II vs. Leica DG 12-60mm f/2.8-4 - a comparison
Kharan
Chile
So, after my G9 vs. G85 comparison, I think it's time to compare a couple of great standard zooms for them. Neither of these is particularly cheap, nor super-expensive, and both fall into a problematic price bracket where most customers expect visibly better results over kit lenses, but also cannot realistically be expected to stand at the top of the optical heap.
Full disclosure: I've owned the Lumix for two months, and the Leica* for three weeks. I bought the PL 12-60mm to replace the 12-35mm, because I wasn't entirely happy with the latter. Still, I think both are good lenses, with different strengths and weaknesses.
And no, I don't own a copy of Imatest, or Siemens star charts. There are plenty of people out there far better-equipped and qualified to run proper, hard tests on lenses. But hopefully you'll still learn a few things from this comparison.
Let's start with the physical characteristics. There's a lot to cover in this department. I'll list the pros and cons of the Leica DG lens, in relation to the Lumix G:
Pro: The PL 12-60mm weighs almost the same as the 12-35mm.
Con: The 12-60mm is quite a bit larger than the 12-35mm.
Pro: The Leica is substantially better haptics-wise than the Lumix. No, the Lumix isn't bad at all, but it's not "pro" zoom material, either. Panasonic got rid of that hideous rubber for the zoom ring on the 12-60mm (yes!), improved the resistance of both zooming and focusing rings (YES!), and added an AF/MF switch on the body (HALLELUJAH!).
Pro: The Leica has an improved lens cap that feels sturdier and is easier to put on/remove.
Pro: The PL 12-60mm has a much better lens hood. The improvements are subtle, but multiple, and show how the lens' design was a labor of love and dedication (which is one of the main reasons behind my decision to use Panasonic gear, as they really love what they do, and it shows). As you can see on the picture above, the hood, when reversed, lies at a 90 degree offset from the Lumix's, allowing users to adjust both focus and zoom even when the hood isn't deployed. The shade has a button to remove it, and it automatically locks itself when in place; this is an excellent addition, because in comparison the 12-35mm's hood becomes loose very quickly and won't stay put. It also incorporates an aluminum piece that in practice does nothing, but feels and looks great :-D
Con: Panasonic increased the filter thread to 62mm on the Leica. Why? Just, why!? If you look at the front of both lenses, their first elements are almost the same size, and Panasonic even chose a narrower font to print on the makeup ring, which doesn't use the whole width - they could've easily kept the 58mm thread. 58mm is one of the three main "standard" filter sizes of Micro Four Thirds, after all.
Con: The PL 12-60mm narrows down aperture-wise very quickly, whereas the 12-35mm has a constant aperture. It's bad enough that I consider the PL a 12mm f/2.8 prime rolled up into a 14-60mm f/4 zoom.
(Very subtle) Pro: The Leica barely changes size when zoomed in to 18mm, and doesn't move at all between 12 and 16mm. This is great for weather sealing, as trombone zooms can easily scoop water inside if they get wet and are pumped often. Of course, the Lumix doesn't extend much more; however, its inner barrel has a rounded flange that won't keep water out, but rather help it slide inside :-x
Equal: Neither has a measurable advantage in either focusing speed or in-lens stabilization, as far as I can tell.
So, how are they for actual photography?
One of my favorite shots from the 12-35mm f/2.8 II.
Color: The Leica DG is an excellent lens. It renders color very beautifully; it's slightly colder than the Lumix G, and it seems to just make reds pop. The 12-35mm has a little more contrast, but it's less vibrant, and tinges everything yellow.
I didn't even need to adjust vibrance for this shot, but it benefitted from a slight clarity and contrast boost. Most of the frame is very well resolved.
Resolution: Remember, first and foremost, that we're talking of a single copy of each lens, and I've no idea how lucky my draw was this time. Anyway, the PL is a bit softer wide open at the edges than the Lumix, but the 12-60mm sharpens up beautifully one stop down, whereas the 12-35mm just doesn't improve much - my copy has a relatively soft left side caused by tilt, which is exacerbated by the IBIS sometimes. In the center both lenses are stupid sharp even wide open, so that's a non-issue. What can be a problem, however, is the relatively pronounced field curvature of the Lumix, especially at the 12mm end, and which can cause corners to seem much worse than they really are. The Leica DG is much better in this regard, and by f/5.6 resolves fine detail way into the corners like few MFT zooms do.
Neither of these lenses is too flare-prone, but the PL gets washed out a little more shooting contre-jour. For a photo like this the Lumix is better.
Flare, haze, and chromatic aberration: Both of these lenses are susceptible to flare, green for the Lumix, and purple for the Leica, in the same situations and to a pretty comparable degree. I can't pick a winner in that regard. As for hazing and loss of contrast, the 12-60mm suffers more of both than the 12-35mm. It's not bad, really; it becomes a nuisance only with diffuse backlighting at the long end. CA is perfectly controlled by the software on Panasonic cameras, but purple fringing on some Olympus bodies can be atrocious with the 12-35mm - I haven't tested the 12-60mm on my E-M10, and don't expect it to be any better.
This is the one aspect where the PL 12-60mm crushes its sibling - its 0.3x magnification at the 60mm end is extremely handy, and blows the 12-35mm's puny 0.1x out of the water. The photo is of a Samsung Gear S2, for reference.
Close up: No contest here, the Leica DG is worlds better. Or rather, the Lumix G is utterly useless and can't compete. Maybe it's both :-P Thanks to its AF/MF switch and really decent focus ring, the PL can sub in for a macro lens not only effectively, but also comfortably.
PL 12-60mm
PL 12-60mm
LG 12-35mm
LG 12-35mm
Bokeh: The one huge fault of the Leica lies in this aspect - its bokeh can only be described as 'hideous'. Both it and the Olympus 40-150mm f/2.8 should be the poster children for "ground aspheric syndrome", or "how manufacturers have made super-sharp lenses that don't weigh a ton and don't cost an eye at the expense of OOF areas". Thanks to a big reduction in the cost of aspherical elements, they've become ubiquitous - but all aren't made in the same way, and the cheapest ones are ground by robots that leave imperfections on their surface. The result is the kind of nervous, oniony, irregular mess that resides in the background of the 12-60mm's photos. If you look at the portraits above (taken at the same time, from the same distance to the subject), the PL should have an advantage with its shallower DoF and greater compression (yeah, sue me), but a cursory inspection of the bokeh leads me inevitably to prefer the 12-35mm. The worst part of the Leica's aspherical mess, however, is on photos where a part is just out of focus, leading to a hazy, swirly rendering that isn't quite blurred, and that could easily lead an unwary soul to think that they bought a lemon. It gives the impression of a cheap 80's zoom shot wide open; it's just awful.
This isn't the best sample, but if you look at the bottom of the picture, it's soft - this is not a problem with the lens itself (I have another shot with the focus point closer to the camera, at the same aperture and focal length, and the pebbles look sharp), but rather with the Leica DG's OOF rendering.
TL;DR (conclusion): Deciding between these two lenses is actually easier than I thought it'd be. If you're a pixel-peeper, get the Leica - it'll give you many satisfactions when peering into the edges and corners at f/5.6, provided they're in focus. If you're a bokeh fiend, get the Lumix - in my experience, it has the smoothest OOF rendering of all MFT standard zooms (I've never owned the Olympus 12-40mm, though, so I'm just going by the samples I've seen).
If close-up capability is important to you, then the 12-60mm is the obvious choice. If a more compact size is paramount, then the 12-35mm is the only game in town.
If you can't decide, get the Leica. It's cheaper right now, it's more versatile, and it's a lovely lens from the perspective of build quality and haptics. That's what I'm doing - I'll keep the PL and sell the Lumix, albeit with a measure of trepidation (it's the only "pro" zoom that my wife has ever liked carrying around, and that's saying a lot).
*Yes, I know it's not a real Leica, but that's what it's called. <German humor> It feels leica premium lens after all, ho ho ho! </German humor>
"Chase the light around the world
I want to look at life
In the available light" - Rush, 'Available Light'
Thanks for posting that. I was converging on getting the PL 12-60 now that it's priced around €750, but perhaps I'll continue to use my Olympus 14-54 a bit more.
Are you using the Four Thirds version with an adapter? I only owned the 12-60mm SWD, and I must say that I prefer the PL in every which way... except for the manual focus clutch of the Zuiko. Those were the good times, when focus by wire hadn't been invented yet :-|
Nice comparison.
I already own the 12-35mm 2.8 and because I hate replacing existing lenses it's only now I pulled the plug on the 12-60. If it weren't for the fact I being given money for birthday + Christmas and of course the Black Friday deals I would still haven't pulled the plug.
Usually I shoot at F4 with the 12-35mm 2.8 and I hate how restrictive the lens in terms of focal length. So it makes sense for me to get the 12-60mm 2.8-4 general purpose lens when I can't bring my primes due to weather or due to travel restrictions impose by myself.
Yes I use the Olympus MMF-3.
That's good to know.
The 14-54 isn't an SWD lens so it's focus by wire unfortunately. But optically I'm quite happy with it, and I like that it's a bit faster in its zoom range (though I seldomly really need that).
Nice write up. I am a big fan of close focus lenses. My Oly 12-40 Pro is excellent. If I lost or broke it itwould be tough to decide between getting the same lens or the PL 12-60. I have the PL 8-18 and find it outstanding in everyway.
You're absolutely right, and I was absolutely wrong. Focus by wire was indeed present in many Olympus lenses from that era.
I've read very good things about the 14-54mm, and knowing how good the 12-60mm SWD is, I can well believe that. But the weight and size reduction alone make the Leica great in my view, and then there's the Dual I.S. 2 with some Panasonic bodies, the instant, silent AF, and the digital corrections...
Nice write-up.
I have been shooting the 12-60 almost exclusively since getting the G9 and it's a gem. If I had to pick a negative it would be more about the susceptibility to flare in certain situations even with the hood.
The characterization as a f2.8 prime attached to an f4 zoom is pretty accurate. Coupled with the Dual IS of the G9 it does just fine in low light.
Like you I was pleasantly surprised at the close focus ability. While not macro I have pulled off some very nice frame-filling flower shots.
All around excellent bang for the buck.
The shots of your dog are absolutely lovely!!
Thanks for the very informatie post - I am a street photographer that used the 12-35 for some years and then decided to lessen weight by getting the 12-69 to replace 12-35 and 35-100 - but it did not work for me I found that instead of getting very close to people I started zooming - after one holiday in Vietnam I returned and sold the 12-60 and bought the 12-35 again - everyone to his on thing!
both are excellent lenses so choice is personal.
Thanks for posting this. I spent a year or so pondering on which of the two to get...until I got my hands on a brand new Olympus 12-40 2.8 Pro for considerably less cash than either of these two. I am very happy with this choice. Even though I use a GX8 which has meh IS, the lens is short enough on the long end that stabilization is not a big deal.
Thank you very much! I take way too many shots of my girls :-P
This is my other dog.
Absolutely. I would tell you the same thing now, if you asked me - the 12-60mm isn't really a replacement for the f/2.8 combo. The 12-35mm f/2.8 is better for street because of its smaller size, too - on a GX85 or GX9 it's very discreet.
My copy arrived today and I had the chance to play with it before it get boxed for Christmas.
This is my first impression and I currently own the 12-35mm 2.8 which I will sell.
I'm not a huge fan of the Panasonic 12-35mm 2.8. If anything I think it's best suited for wide applications rather than a general purpose lens. I don't think the lens had enough reach for a general purpose lens. So in my opinion it's not a good all in ones for travel or event photography.
I did consider getting the Sony A72 along with the 24-105mm F4.0. What I found interesting is one review website rated the PL12-60 higher than the Sony FE 24-105. I don't know if other reviewers agree with this but I found it surprising.
The brand new Canon R has their own 24-105 and the Northrups branded the lens as a kit lens. I thought they were being bigoted as usual but I haven't shot with the lens so I can't say if they're right or wrong. However, I'm under the impression just because it's a 4.0 zoom, it doesn't mean it a kit lens and 2.8 zoom lens is pro lens.
Finally, I own the 50-200mm 2.8-4 and it's a fantastic lens. So my standards for Panasonic Leica zooms are high.
So what do I think about the PL12-60mm 2.8-4? In my opinion it's a kit lens for the GH5 and the G9 cameras. I wouldn't pay full price for this lens. If it weren't for the fact this lens was part Birthday and Christmas present. I would of sent this lens back and down the road either buy the 8-16mm 2.8-4 or the 42mm 1.2.
First off I tested the lens on the GX80 and I think the lens is probably too big. This probably explains why the 12-60mm 3.5-5.6? is bundled with the GX9. It's a shame because I would be gassing heavily over the GX9 and 12-60mm 2.8-4 bundle. I would of likely pulled the trigger. You can still shoot with the GX80 but with the lack of grip and the lens being front heavy, I think it just better with the G9 or the GH5 like it originally intended.
I did take some images to see if there were any softness. It's hard to review the images because it's now officially winter, the light is rubbish and I shouldn't be using zooms until late February. What I did see feels like a kit lens. However, the aim for this lens is for non photographic holidays and going outdoors when it just happen to be raining.
My biggest grip is the distortion in the images. It's easy to spot around 12mm and it's better at 25mm but it's still there. I don't know if Sony FE and Canon R 24-105 has the same problems but it's annoying and something I wouldn't expect from a Panasonic Leica lens. I don't know if the barrel distortion is on the side of the image but in the centre as well? The only to find out is to take photos of a grid.
Overall, I wouldn't say the PL12-60 is the better lens than the 12-35mm 2.8. 12-60mm 2.8-4 is a kit lens for anyone buying the GH5 or G9. The 12-35mm 2.8 is a good lens for anyone doing video or landscapes. If someone need a walk around lens than the 12-60 is better suited but anyone want to do video or landscapes, the 12-35mm 2.8 is easily the winner. The 12-60 maybe a tad sharper but I wouldn't recommend paying almost a grand for this lens. Either get it part of the G9 or GH5 package or look at the 12-60mm 3.5-5.6. It's inferior to the 2.8-4 but I can't see the point in spending all that money just for a polish kit lens.
I find it surprising too - the 24-105mm f/4 G is sharper, and faster equivalence-wise, but suffers from massive vignetting. Still, it's a great lens.
I don't know if someone can be "bigoted" towards a brand of photographic equipment :-P But they were especially kind towards a lens that is far from extraordinary in any sense (except for its grievous vignetting).
But why? Neither of those can replace the PL 12-60mm, even if they're great lenses on their own right.
That's a shame. I don't find its handling particularly different from the Lumix's.
Can you share some samples that you find especially bad? Are you shooting raw or JPEG?
You might be coming at this with a different perspective from mine... or maybe not. I paid $300 for my used-but-in-great-shape copy of the 12-35mm f/2.8 II, so basically the bargain of the year :-D Instead, I paid $650 for a grey market copy of the 12-60mm. So, for me, the PL has to prove its worth - and it has.
Maybe your copy of the 12-35mm is much better than mine, or your Leica is worse than mine. Anyway, I'm sorry to hear that you had a bad experience :(
What annoy me the most regarding the PL12-60 is the barrel distortion. I usually shoot primes and used the 12-35 mostly as a wide zoom. When I took test photos from the 12-60, I was taking images of the house and the garden. Everything seems to morph at 12mm and when I looks at the images, it does give me a bit of a headache. I did a quick comparison of my images but it not scientific, the images of the front door and the PL12-60 barrel distortion at 12mm is worse than 12-35mm.
Overall it's a nice zoom lens but overall I'm not a big fan of kit lenses and prefer to use primes instead. I may of come across a bit harsh but the lens is bit short from a grand so I had high hopes for it. I still think if anyone thinking of buying the lens, they should probably buy it with a camera and get a third off the lens otherwise you're paying over twice as much as the Lumix 12-60.
