robgendreau
As far as I've been able to discover, only Really Right Stuff makes a dedicated system for a quick change of tripod heads (say ball to gimbal) via a round clamp with ⅜" threaded hole to attach to the legs, and then round plates with ⅜" screws to attach to the bottom of the ball head, gimbal, etc. Then they attach as you would with any Arca plated camera, although RRS uses a lever clamp and there isn't any slide to it.
But, it being RRS, it's really pricey.
There are are rectangular clamps with a ⅜" hole that one could thread onto the tripod feet, although usually with a screw clamp, not lever. And one could then use a regular rectangular Arca style with a ¼-20 to ⅜ adapter and attach that to the head or gimbal.
Anyone use such a system? I've got some of the parts around, and although it introduces one more screw that could back out, and you'd have to clamp it down really tight, it seems it would work with say most DSLRs and pretty big lenses. Sure would be more convenient than swapping the heads around, which often has its own issues (sometimes I don't get it tight enough, or accidentally back it off, or have to fiddle with set screws).
