G9 + new SD cards - slow
Started Oct 20, 2018 | Discussions
lescrane Contributing Member • Posts: 903
Usually I use Sandisk Extreme, not super fast, rated v30 3/10 Type 1.  I rarely shoot video or even 6K photos, even if I do, no problems.
I tried a pair of Transcend R95  10/3 rated at write speed 60mb. One in each slot, set on "duplicate".
They lag.   I actually fill the buffer after about 6 RAWS.   I even have trouble "reading" the previews in camera.  They stall out when I scroll through.
I can't figure this out.  Cards are more than I should need.  My only attempted fix was to format each card and start again.  Doesn't seem to help
Any ideas??  (yes, cards are exact same as each other, I bought as a set
tx
 lescrane's gear list:lescrane's gear list
Panasonic Lumix DC-G9 OM-1 Olympus Zuiko Digital 1.4x Teleconverter EC-14 Panasonic Leica 100-400mm F4.0-6.3 ASPH Olympus M.Zuiko 300mm F4 IS Pro +4 more
G Rash Senior Member • Posts: 2,890
Re: G9 + new SD cards - slow
Those are extremely slow cards for the G9.  Run a Google search for the fastest cards for the GH5 and you'll find a good article with test results for various cards.
Gary
 G Rash's gear list:G Rash's gear list
Olympus PEN-F Sony a7R III Canon EOS R5 Nikon D610 Panasonic Lumix DMC-GX8 +3 more
timmer350 Contributing Member • Posts: 939
7
 timmer350's gear list:timmer350's gear list
Panasonic Lumix DC-G9 Panasonic Leica 100-400mm F4.0-6.3 ASPH Apple iPhone 11
rashid7
rashid7 Veteran Member • Posts: 7,011
this has been an issue for me 2.  I have very fast Toshiba cards, and they seem to have a lag in reviewing pix )-;
Keep it fun!
JosephScha Veteran Member • Posts: 7,249
I have a G9, not with the fastest cards but with Lexar UHS II cards (not the worst, either) and there is a perceptible lag when I press ">" to "play" recorded pictures.  It doesn't seem to trouble me, but I have noticed it.  Is that what you are talking about?  I have a feeling it is only partly due to memory card speed.  I wonder if someone with Sony G cards can confirm.
js
 JosephScha's gear list:JosephScha's gear list
Panasonic Lumix DC-G9 Panasonic Leica Summilux DG 25mm F1.4 Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S Panasonic Leica DG Summilux 15mm F1.7 ASPH Panasonic Lumix G 42.5mm F1.7 +7 more
Ted_G
Ted_G Regular Member • Posts: 207
While expensive I budgeted for a matched set of the Pro-Grade 64's. Lightning fast in the G9.
**edit**I note they were not part of the referenced test in earlier posting.
"Lead Me....Follow Me....Or Get The Hell Out Of My Way"
 Ted_G's gear list:Ted_G's gear list
Sony RX100 VA Panasonic Lumix DC-G9 Panasonic Leica 12-60mm F2.8-4.0 ASPH Panasonic 100-300mm F4-5.6 II
HP1999 Veteran Member • Posts: 4,316
Not that it matters now. I use Sandisk Extreme in my Sony and Sony SD in my Panasonic G9 which have two UHS-II slots
Trevor Carpenter
Trevor Carpenter Forum Pro • Posts: 19,435
What does lightning fast mean.  As I see it there are only two speed issues:
1.  Review has lag, I don't care but it worries some people
2.  At 60fps works extremely well but having filed the buffer takes a long time to release the buffer space, although you can start another burst but the buffer size will be limited.
Have you beaten both problems with your new cards?
Recent and not so recent pictures here https://trevorc28a.wixsite.com/trevspics
Panasonic G85 Panasonic Lumix DC-G9 OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S +1 more
MalvinF Regular Member • Posts: 145
Good UHS II cards definitely have improved performance over for example UHS I Sandisk Extreme Pro 95MB/s - perceptible even when powering up the camera, and of course when reviewing images. Was actually surprised at the difference a good UHS II made. Figured may as well use the cards it needs for the times I may need to stretch the buffer.
amipal
amipal Senior Member • Posts: 1,275
I replaced a Lexar UHS II 32 GB card with two Sony G 32 GB cards. They both read and write much faster, with no lag between pressing review and seeing an image.
The buffer clears very fast as well.
Paul
 amipal's gear list:amipal's gear list
Panasonic Lumix DMC-GH4 Panasonic Lumix DMC-GM5 Panasonic Lumix DC-G9 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Leica Summilux DG 25mm F1.4 +7 more
DDWD10
DDWD10 Contributing Member • Posts: 859
I have Sandisk Extreme Pro UHS-2 32GB cards in slot 1 and 2 and there is a very long and annoying playback delay, sometimes almost two seconds.
 DDWD10's gear list:DDWD10's gear list
Pentax Q Panasonic Lumix DC-G9 Panasonic S1 Panasonic Lumix G Vario 7-14mm F4 ASPH Pentax 01 Standard Prime +9 more
Trevor Carpenter
Paul
£192 for 64GB.  I guess I'll just have to put up with the minor inconvenience
rashid7
yes, that's it
Keep it fun!
Ted_G
I cannot speak to "beating" anything. The ProGrade cards were not part of the earlier posters comparison. I can state comfortably that I have experienced zero slowdown in playback and writing that I have noticed. "Lightning quick" is my impression. YMMV.
++edit++I don't usually push the buffer as I rarely use the burst function. I'll pay attention next time I use it though.
For UK buyers I think the Adata V90 cards are well up there on the price performance ratio, and I couldn’t resist such a good offer as can be found if you look. The Sony tough cards seem the absolute quickest of those I have tried, quicker than the Sony G’s surprisingly.
I think for burst or 6K shooting a set of V90 cards is worth looking into to get the most from the G9.
MOD Tom Caldwell Forum Pro • Posts: 46,349
Re: G9 + SD cards - my experience
I have been using Sandisk Extreme 64GB 90 MB/s XC-1 cards in all my M4/3 camera bodies with happy results.  But when I used them in the G9 I only found them “adequate” and although most of the time they were working fine - there were times when their slower performance was annoying.  Given that this was a case of put up with lesser speed performance as an occasional niggle or invest quite a lot of money in truly high performance cards it was something not obviously of high priority.  Especially when I checked the price of Sony G 64GB 300 MB/s XC-2 cards.
It was only when I saw a (relatively) good deal price on these cards after a slow-performance niggle and knowing that I had a serious bit of photographic need coming up that pushed me over the divide.
The Sony G XC-2 cards are obviously far better performaning cards - very quick and no-delay.  But if the need for ultra fast is not great it is not necessarily imperative to spend this sort of money if there is only a niggle or two involved.
As my Sandisk cards have always been more than fast enough for my purposes with other bodies I my pose the question that perhaps this slower-speed niggle is actually from buffering the dual card slots.  I see the dual card slots as something I don’t really need and it has somehow been pushed on to a pedestal of a “necessary” attribute of a truly “professioanal” camera body.  Why?  Is this just another new “video” camera feature pushed on to stills photographers or is it becoming a necessity to have such storage capacity because of high speed capture of stills.  It cannot be a “reliability” issue as Ihave never had a failed SD card.  And the stills photographer recording jpg + rw2 in single shot or short burst must have a huge capacity to do this with just one slot and a 64 GB card anyway.
My guess is that the necessary buffering of a pipeline to two possible SD card slots is actually slowing down the response rates of the SD cards and that we are now findiing it necessary to use the “brute force” of Sony G 300 MB/s XC-2 cards to get a similarly acceptable performance as Sandisk 80 MB/s XC-1 cards were giving on earlier camera bodies which only had one SD card slot.
Maybe it could be possible in firmware to lock the camera into using one slot only and to have to physically swap to the other slot when the first one fills up.  Therefore there should be quicker access - in theory.  But maybe a careful selection of the present options might help.  My selection is to use one slot for “everything” until it fills up and it is still niggly.  But the firmware on a read might monitor both slots and read both cards everytime playback is selected.  We could no know the actual firmware design used to support playback.
Tom Caldwell
Reaper Regular Member • Posts: 281
I have the same issue. I'm using two Hoodman Steel Series 64gb cards and writing jpg and raw to card 1 and video to card 2. When I press payback after shooting 1 photo, it sometimes takes a couple of seconds for the image to display. The read and write speed should be sufficient for instantaneous playback.
Read Speed 300 MB/s Maximum
Write Speed 260 MB/s Maximum
 Reaper's gear list:Reaper's gear list
Olympus Tough TG-2 Sony RX100 VII Fujifilm X100V OM-1 Olympus Zuiko Digital 1.4x Teleconverter EC-14 +7 more
OP lescrane Contributing Member • Posts: 903
Interesting discussion. YES, it's the lag in reviewing that's the major glitch.
My Transcend cards really aren't rated too badlyand that alone should not account for issue. MY SanDisk Extreme(not pro) are rated about the same, and I never noticed problem.
It's a quirk  I suspect it's related to the configuration of the two slots too but need to test it.  Almost like the review function is hunting between 1 and 2. I used to have jt set up with card 1 for stills, card 2 for video. Will try that again w the Transcend and see if the lag is still there.
Ted_G
I have mine configured RAW-->Slot 1 JPEG/video-->Slot 2. I shoot RAW+JPEG presently.
glassoholic
glassoholic Veteran Member • Posts: 7,641
Maybe related... when I got the EM1.2 it came free with a 32GB Lexar UHS-2 300mbs. It was lightning fast. The camera did freeze a bit and then there was a firmware update and after that the card ran a lot slower but freezing went away. I have downloaded a formatting tool for SD cards that you run on a PC to low level format back to "factory" spec. I wonder whether the camera has "written" something to the card that slows it down? As I am paranoid about card reliability, I have not tried the formatting program. And as I always format a card anyways in the camera of use, any file that might slow it down will probably be written back again.
M43 equivalence: "Twice the fun with half the weight"
"You are a long time dead" -
Credit to whoever said that first and my wife for saying it to me. Make the best you can of every day!
