David Hull
Yes, I am seeing it, now that you pointed it out which is a bit telling in and of itself. Not only that but the photo is literally hammered to get it and looks fine when exposed rather conventionally. So, yes, we are seeing the same thing.I'm aware of that but was describing the banding in the example above to help understand if David was seeing what I was seeing as he was referring to "That Streak" which seemed to not be related to the banding in the exampleHe used the camera verticaly, so the banding is horizontal as common.The banding in the example above is in the vertical (Up/down) and looks like purple and green alternating bands of different widths. All seem parallel to the edges. Is that what you are seeing?I looked at that one the other day and that streak appears to be in the actual scene that was photographed - not sure it is from the camera or the processing. It is not parallel to the edges of the frame which I would expect if it were a sensor issue.
I am still trying to figure out whether this is a real issue or just the usual DPR "the sky is falling" stuff that seems to show up with each new camera. I started with a 20D, went to a 5DII then a 5DIII then added an M5 and got good photos with all of them.
Flickr: http://www.flickr.com/photos/drhull
SmugMug: http://davidhull.smugmug.com/
