I'm wondering if anyone has had the chance to compare or perhaps has owned these two lenses. I recently rented the Tamron for a few days, and a person at the camera shop stated he liked it better than the Nikon for a variety of reasons he outlined, but I'm curious if anyone else is familiar with these two. The Tamron I rented was surprisingly nice, and I liked several features on it that were unique to the Tamron. It's also .6 lb lighter than the Nikon.
A world war has been waged over this and there is a fair chance of peace being declared with North Korea first
I've extensively tested and used the Nikon over several years and much prefer the Tamron for what
my needs are.
A few points that
matter to me:
The Nikon is really 200-480mm. I shoot my Tamron at 550mm or more 90% of the time.
The Tamron is fully weather-sealed and has Tamron's best coatings.
The Tamron has a superior 3 way VC/VR system. I use mode 3 which partially stabilises the image in the viewfinder and then fully stabilises the shot at 4.5 stops CIPA. This gives me constant feedback about my technique... absolutely, vitally critical when shooting hand held at the long end. Of course, Tamron VC position 1 works just like Nikon.
I just read something about the VC needing to be switched off when you remove or put on the lens. Do you know anything about that?
As I understand it, any Nikon VR or Tamron VC lens that receives power from the camera has the VR or VC system working all the time until it is switched off. Nikon told me that and I must admit, like most everyone I know, we always forget to switch it off.
When I rented the lens, I didn't know how to use the 3 VC settings, unfortunately. When you say the mode 3 gives you constant feedback about technique...what do you mean?
In Mode 3, the image is not fully stablised and jumps around a bit... similar if the VC/VR is turned off. So, if I see the image jumping about it means I'm not holding it as steady as I could; e,g, if it was on a tripod. So it makes me think about it and focus on my technique. Now, if it is a very small twitchy bird at a distance, I can always put it into Mode 1 (like Nikon mode 1) where the image is stabilised in the viewfinder as well as at exposure.
The Tamron zooms out to 150mm, perfect when the subject gets large and going back is not a good option. Also great for BIFs if the subject flies close. It is possible to zoom out and not clip wings.
I really liked the zoom and how you can lock it at any FL. It's not too loose when turning the zoom, which I like.
Agreed... nothing to complain about and superior to the Nikon.
The Tamron has an optional dock for tuning the lens. For example, I have changed a focus range to better suit my needs. BTW, we have around 6 Tamron's in our group. There are no problems that I know of and the Gen 2's have not required any fine-tuning.
What do you mean you changed a focus range with the dock?
There are focus range pre-sets on most zoom lenses. On the Tamron they are; FULL range; infinity to 2.2 metres, infinity to 10 metres and 2.2 metres (min.) to 10 metres. Using these presets means the lens AF can lock focus faster as it has a narrower range to work in. I changed the middle range to infinity to 5 metres, which suits me better.
I do not know what your use cases are; however, I found this particular review very useful:
https://photographylife.com/reviews/tamron-sp-150-600mm-f5-6-3-g2
Good luck with your choice.
Cheers, Andrew
Thanks for the info. I have to say I loved the G2, but kept thinking isn't the Nikon supposed to be better, that seems to be what all the birders shoot...
Interesting thoughts.
Better in what way? No, all the birders do not use the 200-500 Nikon. The best ones use very heavy and expensive primes whenever they can
In birding, reach is everything. The more "pixels on the bird" the better. Except when they come too close... then the flexibility of a good zoom carries the day.
I owned the Gen 1 Tamron when the Nikon 200-500 came out and we were all excited. Two in our group bought it and an excellent birder and I compared our Gen 1 Vs the new Nikon in Sydney.
We found that for BIFs, we could not acquire focus as reliably as we could with our Gen 1s. We arrived at this conclusion independently and used 4 different Nikon DSLRs in the process. So we kept our Gen 1s even though we expected to buy the new Nikons.
When the Gen 2 came out, I bought it and it is still my "go to" birding lens for its overall flexibility, shootability and image quality.
Since I bought my Gen 2, 3 others in our group have also bought it, 2 have kept their Gen 1s.
Very recently, one of our group sold his 200-500 and has bought a 500PF.
Nikon has not built the 200-500 lens to its highest standards, but to a price. It is a very decent lens but lacks weather-sealing, Nano crystal coat, etc. Nikon had to "geld" it to differentiate it from its pro lens offerings, including the 200-400/4, now a 180-400/4. Hint: don't look at the price until you are firmly seated :-D
The Tamron Gen 2, when introduced was Tamron's flagship lens with all the tech that Tamron could muster. You should get a much longer factory warranty with the Tamron than the Nikon.
As I've tested them, the Nikon has marginally superior image quality from 200mm to around a true 460mm or so. It is getting a little soft wide open at a true 480mm. It is not flash between 150mm to 200mm and not much better from 480mm to around 575mm, the true max for Tamron. It is a 2.5X zoom Vs the Tamron 4x zoom range.
There are a number of independent "reviews" out there. Why not read then (most are not on video or YouTube) to learn the issues, pros and cons and then apply this knowledge to your needs?
Cheers, Andrew
