thanks everyyone, i guess its either not possible (due to the lens layout) or just a really bad idea optically.
If it worked i'm sure it would have been done by now, as the additoinal weight of the converter in a small kit for the day-out would be really handy compared with carrying a whole extra lens.
This morning I have just tested it out a little bit. DO NOT USE IT.
My testing condition:
EOS M5; 50/1.4; Kenko HD 1.4x DGX
Indoor, 1/100, f/2.8, ISO 200.
It seems to work but does not work properly. First of all, AF problem, then image quality, and lastly camera does not operate normally.
Even when camera says AF is done, the image through viewfinder looks dim. So I tried to focus manually, which was difficult because the image through the finder did not look clear. Then I took some shots without the converter and got all clear, wonderful images.
Furthermore, my M5 does not go properly. Automatic exposure goes wrong and the lens or camera made a strange "tick" noise when I went to camera menu system.
I have not idea of 50mm F/1.8 nor other Kenko converters. I have no problem with EFS 55-250 IS STM. However, I can say, Do not use Kenko HD 1.4x DGX with 50mm F/1.4.
P.S. The following has some examples.
Kenko Teleplus HD 1.4X works well with EOS M5. With Kenko the aperture goes down by 1 stop automatically. For example, F/4 lenses become F/5.6 lenses. But interestingly, my 28/1.8 and 50/1.4 maintain their own apertures. Does it happen because they are primes or because they are so old lenses...
www.dpreview.com
