SoupOrPhoto
- Messages
- 1,097
- Solutions
- 2
- Reaction score
- 452
When I think about diffraction limiting sharpness at higher focal ratios (f stops) in photography, I have always thought about this in terms of diffraction experiments in physics. A small slit will lead to photons magically becoming waves with resultant interference or diffraction (I know this is not how a physicist would explain it--I like substituting "magic" for anything weird relating to quantum mechanics).
It just occurred to me that I may not be thinking about this the right way. The reason I question myself is because people often speak of diffraction related to the focal ratio. I would expect that diffraction effects would actually be related to the diameter of the entrance pupil (i.e., the effective aperture).
If this were true, rather than talking about diffraction in relation to focal ratio, it should be considered in relation to the effective aperture (D).
f = (focal length, F)/(diameter of entrance pupil = effective aperture, D) = F/D
so
D (diameter of entrance pupil) = (focal length, F) / (focal ratio, f) = F/f
If diffraction is related to the physical size of the entrance pupil (D), it seems that the effects could be predicted based on D alone. So if you are using a lens with twice the focal length (100mm vs. 50mm, for example), you can double the focal ratio for equivalent diffraction effects. If diffraction effects are seen at f/11 on the 50mm lens, similar effects will be seen at f/22 on a 100mm lens.
I think I must have some fundamental misunderstanding because I have not noticed anyone speaking about diffraction this way. What am I missing?
so
