Fuji X-T1 - Manual Mount Adapter - Focal Length settings = Zoom lens?
Hello:
I have a perplexing question - and not sure exactly how I should (try / attempt / decide),upon which settings to use for the best overall results?
Okay, basically camera is: Fuji X-T1
Lens - Adapted Zoom lens (with focal length range of: 28-85mm).
In the Fuji - provided - setup screen LCD window for:“ Lens Mount Adapter Settings “ - it only provides two (2) manually “selectable” - menuadditions to be manually entered - to suit the lens being used.
Now, how does one (when using for example), ANY - Adapted - Zoom Lens / with multiple focal length ranges / setting - determine the “ideal” (overall) best setting to enter for the focal length?
If I could enter a lot more than only two (2) manually entered focal length settings, I would.
Am I supposed to select - (in my case for example) - lens in question is a 28-85mm focal length range,do I enter the mid-way point between 28-85mm?
To me, these Fuji provided menus settings, seemed to have been designed for ONLY - Prime focal length lenses.
Comments, suggestions, and help is welcomed and appreciated.
I am thinking I could ONLY enter the two (2) most used focal lengths OUT of the overall zoom range?
Quite limiting however.
Looking forward members advice, comments, etc.
Thanks for your time,
Have a nice day / evening -
Ed
Hello:
Ed
