Flashes of Greatness / Nikon 35mm F1.8G review
Richard Murdey
Kyoto, JP
Solid optical performance and good ergonomics / functionality in a relatively light, compact, and inexpensive package.
It makes an excellent standard lens on DX dSLRs like the D3300. Yes, it's worth it over the 35/1.8DX for the nicer and more controlled rendering. This is not open to debate.
On FX cameras like the D750, a good case can be made for the older AF 35/2D for being cheaper and smaller and just as useful, but at the end of the day that AF-D lens is really soft at wide apertures, the corners in particular are quite dire. In some situations that's no big deal, but other times it is.
The AFS 35/1.8G was seemingly designed to excel where the AF 35/2D stumbles most: low light / night photography. Not only is it optimally sharp by f/2.8 already, but flare and ghosting are kept rigorously in check and there is little in the way of color fringing or coma. Bokeh is smooth and attractive with a clean, slightly sterile rendering typical of modern lenses.
A quick note that manually focusing this lens is pretty OK. Modern Nikkors can be a bit hit or miss with laggy coupling or stiff focus rings, but the geared drive here is smooth and light with only a tiny bit of dead time when switching direction. The wide, comfortable rubber focus ring can be moved easily with one finger. I'm cool with it, and I am more picky than most.
AF is of course fast, quiet, and sure.
The only obvious flaw, since I don't consider the mild vignetting wide open on FX important or significant, is the geometric distortion. There is a very slight "moustache" correction, but it leaves a lot barrel distortion especially in the middle of the frame (all the frame on DX crop). It's worse than the AF35/2D and quite a lot worse than my Zeiss 35/2 ZF or, thinking cross-platform, my FA31/1.8 Limited. Overall it is just on the limit of acceptable. While I find it a distraction on any architecture photo it's no so bad as to be noticeable otherwise ... and before you ask: no the software correction doesn't do a satisfactory or pleasing job and fixing it in my opinion.
In summary, this lens is a full recommend. If you can dual-purpose it to both FX and DX bodies, it becomes a no-brainer. It is no classic, however. Instead, Nikon has given us a solid workhorse optic particularly well-suited for low light and general use.
Good review my friend I can't make up my mind if this or the AFS F1.4 (second hand).
Granted, however I would just stop down a little, and it becomes great.
Conversely though at f/8 where I do most of my night photography the sunstars are much much nicer on the 35mm f/2 afd than this new lens.
It's a sharper, more sterile lens that's for sure. Also, it tends to render subjects a lot flatter IMO than the old 35 f2 prime lens I know and love.
How's it compare with the Sigma 35 mm 1.4 ART?
Just curious - which "software correction" have you tried for this lens? I have been slightly tempted to get this lens for some time but I wasn't aware of such distortion issues. If I do get it I expect I would be using DXO Photolab to process any such corrections.
Frank
If you are just looking for a lens to use at f/8 the AFD35/2 gets my enthusiastic recommendation. Outside of f/8-11 though it's not so clear cut.
I can see that. The AFD definitely has more character. I have both lenses btw and on FF at least I like the AFD a lot despite it's lack of sharpness and occasionally ragged rendering.
While you might do all your low-light stuff on a tripod and stopped down, I feel confident in saying this is a relatively uncommon use case. For general use the new AFG lens has a lot of good going for it so I stand by my review above.
Finally. Someone that knows how to write a decent review on DPR. Been so bad as of late I've wanted DPR to drop this option. Kudos to you.
Been shopping around locally for a good clean used version of this lens (I don't buy used off the internet) and there are none, everyone is holding on to them. Nikon has refurbs for $429, so I may go that route.
AF 35mm F1.8G @F4
AF 35mm F2D @F4
Nikon's in-camera distortion correction (D800) does an excellent job with this lens. It matches ACR's distortion correction. I'm not convinced by your assertion that after correction 'a lot of barrel distortion' remains, 'especially in the middle of the frame'. Can you demonstrate? I've photographed bookshelves, head-on, and after distortion-correction all lines appear totally straight.
To clarify, "it leaves a lot barrel distortion especially in the middle of the frame" refers to the optical result viewed on ASPC crop, before software correction.
I don't have software correction turned on in camera, and I don't as a rule enable it when converting NEF in CNX-D.
My comment about software correction not doing "a satisfactory or pleasing job" comes from trying a couple of examples in CNX-D. It works, of course, but second order imperfections leave the photos looking tampered with, to my mind.
I agree that this lens exhibits significant barrel and moustache distortion — more so than in other lenses of this class. I was somewhat disappointed to see it when I first tested this lens.
However this distortion can be corrected completely, either in-camera, or in post.
I've compared Nikon's in-camera correction, with that performed by ACR, and also a more complex distortion-correction routine using PTGui. All three methods produce identical results, and in my opinion fix all distortions, without introducing any other geometric anomalies — I do not see the 'second order imperfections' you refer to.
