voronspb
Saint-Petersburg, RU
The camera with 24-240 mm lens tightly fits into a small bag originally purchased for EOS 400D with Sigma 30/1.4 EX DC HSM lens.
I am a bicycle tourist, and since 2012 in my foreign trips I’ve routinely used the Canon EF24-105/4 L lens on FF bodies (before that I used Canon EF 24-70/2.8 L on cropped body). I was pretty much happy with it, but its telephoto reach was limiting at times, especially for photographing birds and other animals which I meet during the trips. In 2014 I purchased the Tamron 70-300/4-5.6 Di VC USD, which solved the problem with lack of reach in my 2014 Iceland trip and allowed to make some great photos.
But in fact I hated the idea of continuous swapping the lenses while cycling, and also these extra 700 grams were sensible on my back during 2 weeks of travelling. So actually the Tamron zoom was used by me on extremely rare occasions.
I finally decided to change my photo system from Canon to Sony not after introducing the Sony A7III, but when I realized that with this camera I can get the native superzoom glass with reasonable quality, covering most of my needs in cycling tours. So after getting the Sony A7III kit (see my brief review), 2 weeks ago I purchased the Sony FE 24-240 mm F/3.5-6.3 lens, mostly for using outdoors with good lighting, so its slow speed wasn’t much an issue to me.
TL;DR
Pros:
  • Made for lightweight (well, sort of...) travelers, saving lots of space/weight.
  • Lets you make some precious photos, which would be not made at all with other lens.
  • Silent, quite fast and capable AF.
  • Good build for consumer lens.
  • Nice magnification value.
  • Some sort of environment sealing.
  • Reasonable image quality for ultrazoom lens, especially in center.
  • Reasonable weight and dimensions for a full-frame zoom lens.
Cons:
  • Not well suitable for shooting in low light.
  • Poor AF performance in highly dynamic scenes.
  • Ultrazoom makes massive sample variation and unpredictable image quality of each particular lens sample.
  • Image quality is predictably worse than of more specialized lenses.
  • The price is high, as usual for Sony lenses.
Exterior and build quality
The lens comes in small and simple carton box, packed only in a sheet of bubble wrap (no polystyrene bed, or carton holders in the box). You get both caps and simple plastic hood. My lens was produced in December, 2017.
Since 2009 I’ve become used to large weight and dimensions of DSLR camera with standard zoom lens, so the Sony 24-240 mm lens size actually looked quite usual to my taste. The Sony camera with this lens may be put with some efforts into a reasonably small shoulder bag, which was originally purchased for using with smallish prime lenses and could not accommodate any of my past DSLRs with standard zooms. The combined weight of camera and lens is also equal to my previous equipment.
So I don’t call the Sony 24-240 mm lens huge and heavy (which it actually is), unlike many other reviewers. Also note that the adapted DSLR lenses (including many primes, especially modern & fast ones) often become even longer than Sony 24-240 mm due to infamuous 26-mm stack between lens and body. See the size comparison between my old and new cameras: https://camerasize.com/compact/#777.755,380.21,ha,t
This lens has quite good magnification of 0.27x
This lens feels like a modern good quality consumer instrument. It’s mostly made of good but plain plastic, with metal mount, rubberized zoom ring and plastic focus ring. Everything is assembled tightly, the double-extending barrel (aka duocam) doesn’t wobble at all. The focus and zoom rings have very smooth and silent operation. This is a major improvement in terms of build quality in comparison to some of my old lenses: Canon EF 28-135 IS USM had extremely wobbling barrel, and Tamron 70-300 Di VC USD had a zoom ring with rough travel, so it didn’t allow smooth zooming while filming the video.
Unlike many other reviewers, I cannot call the zoom ring “stiff”. It rotates with some effort, slowly, but I’d rather call it “tight and smooth”. I suspect that this tightness is caused by some sort of sealing between the dual moving barrels (there’s some faint whisper sound while zooming). If I haven’t read the complaints throughout the Web about the stiff zoom ring, I wouldn’t have noticed any special at all.
It’s reported that this lens has a weather sealing of some sort, but none is seen on the outside. Probably it’s well sealed for consumer lens, but not so well by standards of L-, G-, or Z-series. After some use it started developing rustling noises when rotating the focus ring, which also was an issue with my old 24-105L and 24-70L lenses.
Autofocus
Unlike old lenses with slow AF, capturing the insects in-flight is quite possible here.
This lens is equipped with noiseless and quite fast autofocus (there's some faint noise due to aperture actuation while shooting at closed diaphragm). Note that your mileage may vary on other Sony bodies. As usual in present days, nothing moves on the outside while focusing. On wide end the focus goes from end to end almost instantly. On telephoto end the full travel takes a bit more, about 0.5 to 1 second, and also in poor lighting the hunting will occur.
In real world scenarios the AF feels instant outdoors, as usually it shifts only by a small fraction of full travel. After some efforts I learned how to photograph the dragonflies hovering in flight. The major issue was that the AF system couldn’t recognize the insect against busy background (pond surface) quickly enough, and every time I saw a hovering dragonfly, I had only 1-2 seconds to aim the camera, focus and shoot.
Despite the good speed, I cannot call the AF “snappy”, as on telephoto end it doesn’t catch up with rapidly approaching objects (like a child running at you). In such cases (probably because of large DOF and poor sensor lighting at F/6.3) you won’t get as perfect focus results as with relatively stable objects. The Eye AF works well in applicable scenes throughout the image field on A7III.
In general, the AF performance is sufficient for a travel lens, and also it vastly exceeds any adapted glass (I tried about 8 different models on my MBV adapter) in this aspect. It’s not the sports-oriented lens, and I don’t judge it as such.
Field quality
There's a sweet spot around 50 mm focal length
I find this lens quite capable in the field (but not in the laboratory). The center is quite sharp, but the borders and corners are somewhat soft (especially the upper right one at wide angle in my case), which is seen at 100% magnification. I fully understand that it’s not the best idea to examine the corners of 10x zoom lens at 24 MP sensor at 100% (as reaching the optimum resolution on ultrazoom in every corner on every focal length is next to impossible). See if this small annoyance with upper right corner could be fixed in service under warranty.
According to my experience, the quality in 24-100 mm range is roughly on par with my old EF24-105/4L mounted on EOS 6D. The center is better on 24-240, but the sharpness uniformity is better on 24-105L. The latter may be not the best lens in the history, but it generates very pleasing photos, and many of them are hanging on my walls for years. The same may be also applied to Sony 24-240 mm. Though I doubt that owners of R-series cameras will be pleased with resolution of 24-240 mm lens.
Shot from the same point as above. The ability to shoot at different angles without a bag of glass is quite pleasing, despite the penalty in resolution.
In 100-240 mm range the quality and contrast somewhat decrease towards the long end, but the photos remain pleasing and usable. Note that on long focal ranges you play against slower AF, natural atmosphere blur, camera shake, shallow DOF, and blur caused by rapid subject movements. So in many cases the blurred photos on telephoto end are not caused by the lens’ optical properties. Generally speaking, I shoot on 240 mm (and sometimes even in 10 MP “crop” mode) without hesitations and without any desire to get closer for better quality. The A4 and probably A3 prints will do well.
The lens speed of F/3.5-6.3 is slow by my standards (generally I prefer shooting at F/2.8 and wider), but for my travelling it’s quite sufficient, as majority of photos are made outdoors during the daytime, so I can easily use F/5.6-8 for them. According to lab measurements, the image resolution doesn’t improve much while closing the aperture, so shooting wide open is OK.
Eye AF works as expected from genuine lens.
Distortions and CAs are usual for a non-pro zoom lens. They are corrected by default, but you won’t be scared after disabling the correction (I prefer correcting the vignetting only when I truly need it). The vignetting characteristic is surprisingly good for a zoom lens on FF sensor.
The optical stabilizer in conjunction with IBIS works quite well until -3 EV at 240 mm, according to my experiments. Though I normally shoot not slower than 1/F to have a margin of safety in unstable positions and so on.
While outdoors, I like shooting the flying vehicles and migrating birds passing over me. With this lens it's extremely easy - simply turn on the camera, set the pre-programmed mode on dial, aim and shoot. No worries about the wrong lens installed, and the ultimate quality is pretty much satisfying. (Especially in comparison to my EF 8-15mm F/4L fisheye, which was the only lens I had when I suddenly found myself in the middle of military exercises with multiple bombers and fighters involved.)
The lighting was poor, but the hull number RA-07314 is recognizable on this Aerospatiale Ecureuil.
To my opinion, the Sony 24-240 mm shall be a pretty nice consumer video lens without prominent flaws. It has a silent AF and smoothly rotating zoom ring. But I’m not a videographer.
Conclusion
A critical scene which exhibits the border softness at wide angle, but in most other cases the corners are not in focus anyway.
This is a good travel lens for mid-resolution FF cameras and their owners which are aware of its natural limitations:
  • If you shoot mostly indoors, get the prime(s) or 2.8 zoom instead.
  • If you don’t have any problems with taking a bag full of glass into the trip, and swapping them continuously, the 24-240 is definitely not for you.
  • If you need excellent resolution and don’t shoot at telephoto, get the Sony FE 24-105/4 G instead (which has much worse vignetting BTW).
  • If you own the R-series camera, then probably 24-105G + cropping to taste will be better for you.
But if you’re the most comfortable with only a single lens in your trip, AND sometimes shoot birds or sheeps, AND own the 12-24 MP FF camera, then you may seriously consider the Sony 24-240.
I spotted the beaver almost immediately after taking the previous photo. With any other lens on my camera I wouldn't have made both of them. [heavily cropped]
Of course, you cannot expect from 10x consumer zoom the quality of modern fast prime or “pro” zoom lens. And it doesn’t work well indoors, unless you have a flash, or don’t mind against the ISO 10K+.
On the other hand, the 24-240mm lens gives you a freedom to swap instantly between completely different scenes, which may be vital in certain situations. Quite often you’ll be getting precious photos during the time while a fellow “pro” with a bag full of F/2.8 zooms or primes would be busy swapping his lenses (or simply looking at you in envy, if he had only one lens). Especially this applies to travel situations, when the weather may be foul, and you may not have time or energy to do the lens swapping.
Speaking of getting the 24-105G plus a compact superzoom as a second camera in place of 24-240 — probably that’s not the best idea. Simply put, even with best superzoom compacts on telephoto end you’ll get around F/12 in terms of light gathering abilities (aperture x crop-factor), which gives 4 times less light than F/6.3. You’ll get either MUCH more noise, or movement blur, or both of these diseases. So the actual performance outside the range of 24-105mm lens would be severely limited…
Bottom line: I’m personally pretty much satisfied with my Sony 24-240 lens, it’s not impressive, but deserves the 4.5 star rating within its application scope.
Vladimir Gorbunov
I'm very happy with this lens for those situations where you're going to need lots of different focal lengths and don't want to carry multiple lenses. I was in such a situation a few weeks ago shooting a baseball camp. It's better than I expected at sports shooting.
These are highly cropped at 240mm.
less of a crop
less of a crop
I have to admit that the next day I brought my 100-400 GM with me for the scrimmage, but these were better than expected.
Gary
Great review. I bought my 24-240 for different reasons. I love the images from this lens on my camera It's an a6000
Late August two years ago I broke my left shoulder right across. I had to change lenses, but didn't want to with my arm in a sling.
I bought the 24-240 and it was perfect. Wider angle? I use my rx100-2
combination works well for me, and gives me incredible range on my Sony a6000
I prefer it at the widest aperture I can select. Don't know why...but I believe the a6000 focuses better that way
And I have a bridge lens if I win the lottery and go full frame.
DaveL
Toronto
Thanks a lot for this comprehensive review. Very useful and spot on.
I can get this for around U$820-850 and U$780 gray. The plan is to get this lens as an all around and the tamron 28-75 f2.8 RXD. I got the Tamron first because it was the one available, and
I also bike and I think this is a good lens for travel. But I think the a7-3 is still a bit big for travel. I might gravitate to a MFT for such things. But the fact I already have the a7-3 means I can always change my mind. Either way, the possiblities are open.
Thank you! In my cycling trips for carrying the camera I use the Ortlieb Ultimate 6M handlebar bag (with photo insert). There's enough place for my Sony A7III with base plate and large lens (24-240 fits with hood in shooting position), also a spare battery, Xiaomi spherical camera and mobile phone.
I use this FF lens (24-240) on my a6000 for reasons I explained in another answer here. I haven't taken it off my a6000 since I bought it!
It works well for me. Range suits me very well. Effectively 36-360 on my a6000 It is a heavy combination, compared to the kit and moderate telephoto lenses I used to have.
I have an RX100-2 with the Sony accessory eye level finder when I want to travel lightly.
Are you really sure that its resolution is enough to cover the 24 MP cropped sensor? I've started considering the A6000 (or A6300 at good deal) as my second camera, replacing the LX100. Having two cameras with 100% inter-compatible lenses is an intriguing idea!
Nice honest review, of a nice underrated (I suspect often hearsay) lens.
Yes, the lens has some cons, but many pro's. In the end, no lens have everything
This review has made me more happier about getting this lens (waiting for delivery), although I'm more worried about the size and weight than image quality. Then again it's smaller and lighter than the other faster lenses at that length.
As for the slowness, I got the Tamron 14-150mm f/3.5-5.8 for mft because of it's range. It's also not to bad and sits on my camera most of the time, unless I want longer, shorter or faster which is not a lot on a walk about.
I'm useing mine as family/zoo/soccer mom lens and it works very well for that. I would not use it on a high resolution body but for normal foto prints/family foto books quality is fine.
My lens sharpens up a little in the center at 200/240mm and is quite useful in this zoom area - and is my only long zoom lens. Normaly I also throw in the 55/1.8 for some portrait/indoor fotos - which is a more useful combination for me as 2 big and heavy zooms.
An excellent, well-balanced review of an under-appreciated lens!
I sold mine as soon as the 24-105 F4 became available for precisely the reasons you mentioned, but I took hundreds of very fine photos with the "all-in-one" zoom.
I now have to carry the 70-300G with me if I want better performance at the long end which is a compromise in comfort I was willing to make.
Cheers
Thank you!
I asked the local Sony service center to examine my lens for optical quality, if everything's within specs, especially that blurry right image border on wide angle. They sent the lens to leading Sony service center in our capital city, which has the necessary equipment.
I hope I'll get the lens back before departing to my vacation trip on 21th of July, and also I hope that the lens won't become worse than before, at least. :)
Quick update. Today I called to the leading Sony service center in Moscow. They told me that my lens was out of spec, and they ordered necessary small parts for fixing it. Unfortunately, one piece is still lagging behind, and therefore I will not get my lens back before leaving to my vacation trip. Such I pity - I purchased this lens specifically for using in this trip.
Vladimir Gorbunov
Ok, so if I understand this correctly, you bought a brand new lens and it was found faulty by Sony. At this point shouldn't you be getting a new replacement lens instead of waiting while they refurbish their faulty lens? I know if it were me, I'd be asking for either a new lens or my money back. Maybe this not how it works in Russia?
I don't think so. I need a lens which was carefully adjusted by hand in official service. Not the brand new one with possible problems at another focal length.
I'm fully aware that ultrazoom makes huge sample variation and treat this as a fact. Also I don't have equipment and time for testing each corner at each FL, then replacing the lens again and again to find the perfect sample (if it really exists). Manual adjustment in service is a lot more straight-forward way to achieve desired quality.
There's a possibility that I'll get my money back in place of my lens, and in such case I won't be really happy. Instead I'll delay the lens replacement until 2019, as I don't need such kind of lens in mid-season.
Well, good luck with that. There is a possibility the lens will come back to you worse than it was, you said so yourself, or more likely it'll return no better than it was, as this lens is what it is. I I don't expect this lens to be as sharp across the frame as my wide angle primes, and I know it isn't because I can compare, that's why I keep and use the primes when it matters.
According to the tests, this lens shall not be soft at edge of frame at wide angle. Especially on 24 MP body.
Also they've already told that this lens was actually soft on their A9 body.
Vladimir Gorbunov
