SilvanBromide
Because of reports like that about the 70-200 GM, I held off for over a year.Thousands reported how great the AF works because none of them tore the lens apart to see how it works. Only one guy did. The AF is very quick, silent, and accurate for the vast majority of people. That doesn't negate the fact that it's held together by a dab of glue. It also doesn't negate the fact that I'm not the only person that has reported AF noise.I have never heard a single report of a failure in terms of the AF-system, but thousands reports how great the AF works ! He was also the only guy which totaly talked down the 70-200GM, in the meantime 20 other tester higly recommended the lens.The AF motor has a high rate of failure due to how it was designed. More info here: https://www.lensrentals.com/blog/2016/04/a-look-at-electromagnetic-focusing/I've read one highly critical review that said that while the lens is optically excellent, its mechanical construction is poor, and it breaks down fairly easily even in normal use.
I normally consider one-off reviews like that with a jaundiced eye, but at the same time this is a very expensive lens.
What has been the experience of people who have been using this lens for some time (as it has been out for some time), both good and bad, as far as its construction?
Other parts of the body shouldn't be too different from other Sony lenses.
There have been numerous other reports of the 70-200 GM not being as sharp as the competition. Both review sites and actual consumers on forums have reported this. It is perhaps yet another victim of sample variation but nonetheless he's not the only person on planet earth who felt the lens was less than sharp.
When I finally relented and bought one I was resigned to it being passable but probably little more. On the first outing with it I was floored. It is easily the sharpest 70-200 I've used.
I've since seen similar results from other copies. Wish I'd bought it sooner.
