Sony A7 III IBIS problem
psou
New member
Greetings from Greece!
I am a photographer and i currently own several Sony A series mirrorless bodies.
I have come across a problem with one of my Sony A7 III's.
Yesterday the IBIS started doing weird stuff although, it was not even on.
From a bit of research that i have done it seems that there are more like me that had the exact same problem and therefore, i believe that it should be addressed and documented for proper handling. My S/N is 3778491.
If anyone else has or had this problem please let me know. Knowing the serial number is also useful.
Check attached video!
Thanks!
Well, I tried a sensor recalibration process and IBIS started working again as it should.
I will do more tests and revert.
Unfortunately, today in the middle of a wedding the camera malfunctioned again.
Sending it back.
Any feedback from others that had to return it?
So...the news are that Sony will NOT be replacing the camera at least for now.
They will be sending it for inspection (although it doesn't work) and possibly repair to Poland. They seem not to have addressed this issue yet.
Dont know where your from but if you got in within 30 days online, get a refund and buy another one.
Wow - that is violent sensor shaking. Hopefully, they swap units and get you up and running quickly.
This guy talks about the same problem.
I am worried because this problem seems to be appearing in cameras globally.
Sony needs to step in.
Not an option I am afraid. :(
The camera is old, 1.5 Month
I have exactly the same problem. My A7 iii was bought in B&H in NY and I took delivery on the 27th June so it does look like it could be an international issue. Only problem for me is that I'm in London for the next few months so I can't easily return it and my warranty doesn't cover Europe. Hopefully Sony support UK will sort me out...
I have the same Problem from a pre-order unit... bought it from Adorama: Placed April 24, 2018 Delivered 05-29-18 SN 3387958
Same problem. Purchased from Adorama in US in May, 2018, so an early unit. Precision Camera, Sony's US warranty contractor ultimately replaced the image sensor and image stabilizer. Sony's repair line is combative when you contact them. I was asked if I had dropped it, etc. They individual said he had only seen this problem with a camera that someone in their area dropped during cleaning. It felt like they were trying to get me to say something to get them out of their responsibility to fix their (apparently known) manufacturing defect.
The first time I sent the camera to Precision Camera, it came back having had only the sensor cleaned. The second time, initial Sony repair person was also combative, "Did it work when you got it back?" suggesting by his tone that I had broken a camera that had been properly repaired the first time. They seem more concerned about avoiding responsibility than fixing the problem. You never hear from Sony, "I'm sorry for your problem and inconvenience, lets see what we can do to make it right." Sony is more concerned with their 'Policy' than customer satisfaction (you hear 'policy' a lot in a conversation with them). Their customer service representative even said that replacement isn't covered under warranty - only repair (the US warranty DOES list replacement as one option Sony may choose to resolve the problem). It's best to ask the repair line to escalate you to customer service, they are slightly less combative and slightly more helpful.
Sony is pretty hands off with the Precision Camera interaction, and Precision Camera is extremely difficult to contact by phone. If you do get through to Precision Camera, they are helpful and pleasant though. Sony will write up your problem for the Precision Camera work order. DO NOT RELY ON THE SONY WRITE UP ALONE! E-mail Precision Camera with image and video samples if you have them and describe the problem in detail. Be sure to tell them that the problem is 'intermittent,' or you may get your broken camera back with nothing more than a cleaning.
I am fortunate that this problem didn't happen a couple of months later or my camera would have been out of warranty, and given my experience with Sony repair and customer service representatives, my impression is that they would try to avoid responsibility even though other units manufactured at the same time seem to have had the same manufacturing defect.
If you're reading this, maybe you are having the same problem. Good luck!
Called SONY and they gave me a lame attempt at fixing the camera with a battery yank and hold the shutter button down with the power on and no battery... of course that did not work. Still having problems with the camera crashing but now the IBIS is not freaking out like before. I have 10 more days until a calendar year is up.
11 months later from creation of this thread - I have the exact same problem, violent shaking of the sensor. camera worked flawlessly for 15 months, upgraded to V.3 Firmware and off it went, right in the middle of a professional shoot.
I've tried the factory reset, pressing and holding the shutter release with no battery, turning on and off etc but its still there. Contacting Sony this week, thank goodness its still under warranty!.
Did you update to 3.0.1?
Since I’m not a one-time poster, I wonder if I should be worried about this...
Yes, updated to 3.01 too, sorry I should have said that in my post. I had thought 3.01 was the fix to a fault on IBIS introduced on V.3, but sadly not.
Lol, well in the grand scheme of things its probably just a small number of cameras that are affected - I follow several Pro Sony users on Youtube and none of them have commented on this problem AFAIK so it doesn't appear to be as bad as the Nikon D750 issues that resulted in several recalls :) (yet!)
