km25
Leading Member
[No message]
Hi. I'm very sorry to resurrect this oldish thread but I would appreciate some help.That partially depends on your requirements. Godox/Flashpoint have two Fuji models, one smaller and less powerful than the other (TT 350F), and both capable of remote radio triggering and and HSS. The better 'fit' on the small Fuji cameras is the smaller unit. The larger (TT 685F) is about the size of the Fuji flash, but is considerably less expensive. If you intend to do a lot of outdoor fill flash, or indoor bounce, then I would suggest the larger unit.
As for model numbers, Godox (the manufacturer) and Flashpoint (Adorama's house brand) use different numbers for the same unit, and there are also versions that use a propriety Li-ion battery pack instead of AA NiMh types, but a quick search will give you more detailed information.
It's a fine flash to start with. Especially for learning without spending a lot of money. It's a great size fit for the Fuji bodies as well. The larger flashes are necessary for a lot of types of work but they honestly feel oversized on an X-T2.The Godox TT 350F is within my budget. I was wondering whether you'd consider this to be a good start in order to start learning how to properly use flash in portraits and maybe some product/macro shots. My understanding is that should I learn it well and enjoy it, I would have to invest heavily into more units etc. but would the TT350F be a good way to start wit the Fuji X-T2?
Thanks for the detailed answer! It's the inadequate power that had scared me off, but tbh, being a complete noob with flash photography I figured that it could be a good start. I also cannot find the 120$ deals and even if I did, it would be quite complicated for me to order from the US. I have now discovered there's also a li-on battery version of the small one and am strongly considering getting that for black friday.Hi.
IMHO, Godox TT350F is a great match for X-T2 size wise. However, some folks here have complained about its sometimes inadequate power.
Personally, having researched options, I decided to match my X-T2 with a bigger unit with Li-on battery -- essentially, Adorama-rebranded Godox model with USA warranty.
https://www.adorama.com/fplfsmzl2fu.html
The flash is now on sale and, if purchased from Adorama on eBay with their 10-15% off coupons, can be had for $125-135.
I will experiment with using just one on-camera flash and then see if I might ever need to use an off-camera flash setup. If so, I will also pick up this controller (the newest, Mark II version, soon to be released):
https://www.adorama.com/fprrr2profii.html
PFB thread for additional opinions.
https://www.dpreview.com/forums/thread/4267924
Thank you and kindest regards.
Thank you, especially for giving me Neil's name. I am going to look him up and try to learn from him. I almost bought one of the bigger, stronger versions this morning, but last moment found the strength to not spend that much money I don't really have. I'm strongly considering the V350F which is the same but with the Li-on battery.It's a fine flash to start with. Especially for learning without spending a lot of money. It's a great size fit for the Fuji bodies as well. The larger flashes are necessary for a lot of types of work but they honestly feel oversized on an X-T2.The Godox TT 350F is within my budget. I was wondering whether you'd consider this to be a good start in order to start learning how to properly use flash in portraits and maybe some product/macro shots. My understanding is that should I learn it well and enjoy it, I would have to invest heavily into more units etc. but would the TT350F be a good way to start wit the Fuji X-T2?
Start experimenting with bounce flash as well. I recommend reading (or watching videos) from Neil van Niekirk. Get yourself a piece of craft foam and a rubber band (or elastic hair loops) and you can produce great photos with the on-camera flash.
