D500 vs D7500: differences?
Johnsonson
Well-known member
Looking to buy a Nikon APS-C camera.
Seems like the D500 is the flagship but besides the dual memory cards is there big difference between the 2? It's going to be permanently mounted to a Tamron 150-600mm.
the d500 has excellent tracking and speed, but then again the d7500 has the same sensor, image processor and metering system. it gets 8fps which is plenty of speed imo. however it doesn't have the same autofocus system, but does have group autofocus.
the d7500 also supports wireless flash (which the d500 doesn't).
honestly, unless you're specifically looking to get a d500, there's a lot in the d7500 which makes it my pick for someone looking to get a "nikon aps-sc camera" that will be mated to the tamron 150-600mm. if not for birding (assuming that is the use for that lens), maybe a d7200 would be sufficient.
fstoppers article comparing the two: https://fstoppers.com/gear/nikons-new-d7500-shares-much-d500s-dna-172695
It is indeed for birding. Thanks for the info, I thought it had the same AF system. That's probably the thing that matters most.
Ding, ding, ding! Yes, for birding you want the fastest AF and best tracking you can get. Right now the D500 is the way to go (aside from a D5). The 10 fps doesn't hurt either ;-)
Besides the AF system, another huge difference is the grip if you are using big heavy lenses.. The camera balances much better with a grip on it. There is no grip available from Nikon for the D7500. If price is an issue check the used markets but the current deal that includes the grip is pretty good...
The buffer is much larger on the D500, assuming you buy an XQD card for it.
The D500 has Group Area AF.
The D500 does support wireless flash, but it doesn't have a built-in flash; there's a difference.
The D500 is more expensive, no doubt, and the XQD card and "need" to have an external flash to IR trigger remote flashes are part of that extra expense. OTOH, the D500 has dual card slots, has more external controls, a round viewfinder (I don't care for the rectangular viewfinder), and it works with more lenses because unlike the D7500 there is an AI tab on it and it will meter non-chipped lenses (more details about this here).
Regarding that last point, I would also add that the D500 is better suited to using the PC-E lenses than any other DX camera, and I wouldn't just presume it to be only the best DX choice if you are birding or doing similar types of photography.
Hello, For me the choice was easy. I, like you, have the Tamron 150-600 G2 and use it with my D500 most of the time. It is almost always mounted on my D500. I chose the D500 primarily for the speed, 10fps and the auto focus speed. Second was the ergonomics, they are much better on the D500 with larger lenses, if feels great in the hands (hard to put it down) and balances better with larger lenses. Plus the button layout is better, the viewfinder coverage is 100% and has a built in shutter. Another must have for me was the dedicated AF-ON button. This is my primary method of autofocusing and not that I am used to it, I can't imaging doing it any other way. So I would consider these things heavily before making your final choice. Plus, with the grip deal Nikon is running, its worth paying the extra for the D500, IMHO.
...the [D500] viewfinder coverage is 100% and has a built in shutter.
I'm going to give you a thumb's up here, but both cameras have 100% coverage; the D500 has 1x viewfinder magnification whereas the D7500 has viewfinder .94x magnification.
If the D750 is anything to go by (same AF as in the D7500), you're not going to see any significant difference in AF speed with a slower telephoto like the Tamron 150-600mm G2, whether it's mounted to a D500 or D7500.
I use my D500 and D750 side-by-side nearly every weekend all day long, swapping lenses for a different focal length between them and I get the same keeper rate from both cameras.
I think you'd only see a bigger difference if you had a TC attached (and I did notice that difference when I put a TC on my Nikon 200-500mm), or mayhaps (and I'm not even sure about this) with the faster, newer Nikon "E" lenses.
If you want to save money and still have a great birding camera, I'm sure the D7500 will do a great job. The D500 is great, but is the barely noticeably better AF and 2FPS worth the extra few hundred bucks? Not to most people IMO.
True.
That's debatable. Wider coverage area counts for something by itself, and you described a detectable improvement with TC's that can manifest itself in other ways that can end up making all the difference. Nonetheless...
Also a much larger buffer.
Currently at B&H Photo the difference is about $600 for refurbished cameras, which doesn't account for the extra cost of using the XQD card slot. However, right now you would be better off buying the D500 with the MB-D17 which mitigates the $700 less you would pay for a brand new D7500.
True. However, I personally value the better viewfinder, the larger buffer, the better ergonomics and UI, the PC and 10 pin terminals, greater lens compatibility, and the second card slot is nice too. Some would also place some value on being able to mount that MB-D17 on the D500. OTOH, the D7500 is smaller, and for some that is a virtue, and there's that built-in flash.
As I see it, a purchase like this should last a few years, so take the price difference and divide it by say 60 and you would be paying something like $15 extra a month to shoot with a D500 instead of D7500 over the next five years, and right now you would have that MB-D17 available to put on the D500 whenever you wanted to use it.
I was lucky that the D7500 had not been released yet when I bought my D500; so it was easier to take a decision. Nevertheless I would not change today. The D500 offers:
  • large, bright viewfinder with round eyecap (noticeably better than my old D90 that might be similar to the D7500 in this respect)
  • amazing AF system -- inherited from D5
  • AF joystick -- I use it a lot (don't even remember how I could select an AF point without)
  • virtually endless buffer -- never experienced a problem with SD cards
  • high-res display (2.36 instead of 0.92 Mdots like D90 -- significantly simplifies analysis of focus in camera)
  • illuminated buttons (useful in dark environments, e.g. during events)
Last but not least: my "baby D5" makes me smile whenever I pick it up. I spend a lot more time with taking photos than before.
Your "baby" D500 is too "young" to have the much higher level of banding noise that the real, grown-up D5 has.
I never had the D7500 but I am not sure it has all the program-ability the D500 does either which is a big plus for birds... setting up different AF groups on separate buttons etc.. all I know is it was worth the upgrade from D7200 just for that, along with FPS, buffer and AF speed. . But maybe the D7500 does all those things as well.
here's another thing... even though they share the metering, image sensor, image processor.... rumor is the D7500 auto exposure is better
Please substantiate this. Rumor from where, and based on what?
