Dark Penguin
Well-known member
- Messages
- 113
- Reaction score
- 18
My astrophotography has been fairly hit or miss so far. I have taken shots from parking lot of my apartment complex, located in a typically light polluted residential neighborhood, and successfully post-processed the images to the point where they resemble the night sky in a dark sky location. In the best examples, the stars show their proper colors, e.g. red for Betelgeuse, orange for Aldeberan, etc.
On the other hand, I have taken other photos from under a dark sky, and paradoxically encountered far greater problems in post processing. A recurrent problem is that the star images usually come out too small. Even in an unedited image, what appears at first to be nothing but washed out sky turns out reveal numerous stars, some as faint as 7th magnitude, Darkening the background sky as much as possible certainly helps a great deal, but the star images themselves are still too small.
I'm most familiar with GIMP though I do also have access to Lightroom and Photoshop. In GIMP, as I suppose is true of similar tools, you can "grow" a selected area by a specified number of pixels. If I select all of the star images in the photo, the grow tool will extend the radius of each star image by that many pixels, but a huge drawback here is that the magnitude range is flattened. For example, in an image of Jupiter the central bright area might be nine pixels in diameter, while the corresponding area for Ganymede is just a single pixel. If I grow all the images by two pixels, then Jupiter becomes only about 1.5 times brighter than it was before, perceived brightness being based on the area of the planet's image as it appears in the photo. Ganymede, on the other hand, now becomes more than 10 times as bright times as bright as was in the unedited photo. You wouldn't think it matters that much since the overall image still accurately shows that Jupiter is brighter than Ganymede, or that Sirius is brighter than Wezen. But it still gives the photo an artificial and faked aspect. What's worse is that familiar constellations now become difficult to identify since the differences in the brightness of stars is important in telling them apart. Orion becomes lost in the background when the three stars in the belt appear almost as bright as Rigel and Betelgeuse, and the shield stars are almost as bright as the belt. Still another problem is that star colors, which tend to show up around the edges of a stellar image, go completely missing, making the stars all pure white.
I have a Nikon D5600 and for astrophotography I use the 18-55mm lens that came with it.
