S
SaltyPeanut
Guest
Anyone used/compared these two by any chance? Looking for a portable setup for outdoor shooting. Umbrellas are hard to control outdoors. Assume the octa would have the additional deflector.
TIA
TIA
Gonna let some others chime in first but wanted to point out that the 26" is a speedlight modifier and the Beauty Dish comes in one of several studio strobe mounts and would require an adapter for use with speedlights. In addition, you may want to consider the Rapid Box Duo (my personal favorite).Anyone used/compared these two by any chance? Looking for a portable setup for outdoor shooting. Umbrellas are hard to control outdoors. Assume the octa would have the additional deflector.
TIA
As far as I can tell, both place the speedlight outside the box, looking at pics on Westcott's website. Good call, this will matter initially as I don't yet have radio triggers.One thing to check is whether you need "line of sight" from your camera to the flash unit, and whether the flash unit is hidden by the softbox.
I do not know which Westcott works which way.
BAK
Pete, I don't see how, but is there any way to mount a Godox AD200 to the 26" speedlight box?Gonna let some others chime in first but wanted to point out that the 26" is a speedlight modifier and the Beauty Dish comes in one of several studio strobe mounts and would require an adapter for use with speedlights. In addition, you may want to consider the Rapid Box Duo (my personal favorite).Anyone used/compared these two by any chance? Looking for a portable setup for outdoor shooting. Umbrellas are hard to control outdoors. Assume the octa would have the additional deflector.
TIA
Pete@Westcott
The bigger the subject the bigger I want my light source to be. For portrait soft light I want the diffuser to be as large as or larger than the subject and I will use it at a distance of 1 to 2 times the diameter/diagonal of the diffuser.What would make more sense, a ad200 on a 36" rapid box, or a 32" duo with 2 speedlights? For portable outdoor use, 1-2 adults to small families, aided by a reflector if needed. Box sizes are so close I assume light coverage/falloff are close enough to be negligible (could be wrong). With all the mounting options out there, is it possible to use either set of lights on either or these boxes? Just trying to get a sense of how much versatility is possible.
I believe you need one of these to convert the RapidBox 26 octabox to the bowens mount. It seems pretty pricey for what it is.
https://www.adorama.com/wesrbwo.html
I've got the same softbox and I'd like to convert mine to use with my AD200 but not sure I want to spend the money.
Thx. I might try this, with them sitting down on a blanket.For a small family of 3 or 4 people (Clay Blackmore - Group Posing Guide) I might use a single 43" umbrella but would expect some fall off at the feet for a full length portrait or slightly harder light for a group. I would prefer either a 60" umbrella or two 43" ones side by side for such a group. In most cases I use a white umbrella with a black backing in the reflection mode.
Wouldn't the ad200 be too close to the reflector? Bare bulb on the ad200 for best results?For a 60" umbrella I would look at the AD200 with the Godox S-Type Bracket for Bowens and a 120° reflector to prevent the spill of light beyond the rim of the umbrella.
Amazon.com - Godox Aluminum 120° 12.2" Wide Angle Reflector Bowens Mount Diffuser Dish for Photography Studio Strobe Light : Camera & Photo
To use this reflector with an umbrella you need to mount the reflector, slide the umbrella stem in from the back of the S-Type bracket until it butts up against the reflector, tighten the umbrella holding thumb screw, and mark where the stem hits the reflector. Drill out a hole at this position so the umbrella can pass through the reflector and into the S-Type bracket.
I understand that the current S-bracket offering will fit the AD200 for mounting to any of the studio mount Rapid Boxes including the 24" Beauty Dish. I have mounted an AD200 to the 26" Rapid Box and a Duo using the tilter (included with many AD200 Including the Evolv kits but not all) and replacing the cold shoe on the Rapid Box with a 1/4-20 female spigot. I think The limited depth for inserting the AD200 into the 26" Rapid Box make the speedlight head a better choice for that modifier but I prefer the Deeper Rapid Box Duo (larger opening) combined with the Bare bulb head of AD200. For the Duo, do not attach the twin cold shoe bracket and screw a 1/4-20 spigot on in its place.Pete, I don't see how, but is there any way to mount a Godox AD200 to the 26" speedlight box?Gonna let some others chime in first but wanted to point out that the 26" is a speedlight modifier and the Beauty Dish comes in one of several studio strobe mounts and would require an adapter for use with speedlights. In addition, you may want to consider the Rapid Box Duo (my personal favorite).Anyone used/compared these two by any chance? Looking for a portable setup for outdoor shooting. Umbrellas are hard to control outdoors. Assume the octa would have the additional deflector.
TIA
Pete@Westcott
I think that this vid has some useful info. It's a bit difficult as I can't turn up the sound right nowKrav - I have the S-bracket but it's not obvious to me how I would attach it to the 26 inch rapidbox.I think people have used these to us an AD200 with a Rapib Box. A much less expensive solution.I believe you need one of these to convert the RapidBox 26 octabox to the bowens mount. It seems pretty pricey for what it is.
http://www.flickr.com/photos/107641481@N02/
I feel more like I do now than I did before ...
https://danielmedley.smugmug.com/
No.Thx. I might try this, with them sitting down on a blanket.For a small family of 3 or 4 people (Clay Blackmore - Group Posing Guide) I might use a single 43" umbrella but would expect some fall off at the feet for a full length portrait or slightly harder light for a group. I would prefer either a 60" umbrella or two 43" ones side by side for such a group. In most cases I use a white umbrella with a black backing in the reflection mode.
Wouldn't the ad200 be too close to the reflector?For a 60" umbrella I would look at the AD200 with the Godox S-Type Bracket for Bowens and a 120° reflector to prevent the spill of light beyond the rim of the umbrella.
Not necessarily so.Bare bulb on the ad200 for best results?
