The new 16-35 mm SL zoom is huge, heavy, and expensive, and if it is like similar recent offerings from Leica, it will be an under-corrected optical design that relies on software distortion correction, yet it has a variable maximum aperture like a cheap kit lens! It seems a bit underwhelming.
J.
Surely that's not a surprise? The 24-90 was variable aperture and physically very large. The 90-280 was variable aperture and physically very large. Why would the 16-35 be any different?
As far as the use of software for correcting distortion, lateral CA, and vignetting... Within limits, I actually like the concept. For a given size and weight, it allows the final image to be better than it otherwise would be. The same approach is used by:
- Leica
- Nikon
- Canon
- Fujifilm
- Sony
Basically, anyone who designs lenses and bodies to work in concert has adopted this approach. It leaves the optical engineer the ability to give higher priority to addressing other factors such as longitudinal chromatic aberration, spherical aberration, spherochromatism, astigmatism, and coma. It's really all about the final image, and it's not like you were going to use an SL lens on a non-Leica camera, so there really isn't much of a down side. I suppose one could claim they should have addressed the issues in the lens design rather than in software, but something else would have to give.
As far as the variable aperture goes, to get a zoom to have a fixed minimum focal ratio, you basically need to design the lens to have the maximum aperture at the telephoto end of the range, then mask it for shorter focal lengths. That requires more glass and more expense than what Leica is doing. The lenses are already heavy and expensive enough, in my view. I wouldn't want to carry around a 90-280 f/2.8 constant aperture lens. Heck, I wouldn't even want to carry the current 90-280.
So, am I underwhelmed? Nah. The 24-90 is unquestionably the best zoom I have ever owned. It's a huge improvement on the Nikon 24-70 f/2.8, for example.
