Dwiptrlatief
Forum Enthusiast
- Messages
- 286
- Reaction score
- 30
halo,i see many people using NR in negative value,lets say NR -2 are you guys adding more noise reduction on editor/pp or just leave it?
are you using NR -2 (or more)?and you said you rather do NR on pp,so you adding more NR on pp,right?depends on the image. The noise reduction setting really only applies to the JPG image. But some say Fuji actually applies NR to RAW files also.
In any event I'd rather do it in PP.
I have my T2 set to -4. E2 set to -2, lowest.are you using NR -2 (or more)?and you said you rather do NR on pp,so you adding more NR on pp,right?depends on the image. The noise reduction setting really only applies to the JPG image. But some say Fuji actually applies NR to RAW files also.
So you make those changed in the NR settings depending on what ISO you are using?Basically NR only relates to JPGs. It´s a balance between noise/"grain" and sharpness and detail.
My prefs for XPR01+2 are: 200 iso to 6400 iso is -4.
Above 6400 -2 to 0 depending on dirty colours. ( dark brown/ greys etc.) I can always add more NR if needed in pp, getting rid of to much Nr - not possible.
ok then,but are you adding more NR on pp when needed?I have my T2 set to -4. E2 set to -2, lowest.are you using NR -2 (or more)?and you said you rather do NR on pp,so you adding more NR on pp,right?depends on the image. The noise reduction setting really only applies to the JPG image. But some say Fuji actually applies NR to RAW files also.
I don't want the Camera to do any NR. But from what I read with any Fuji camera it always does some NR no matter what you have it set to.
Well, you can do it via the Q menu as well so its not all that time consuming. In my experience you don't need to change the NR with slight ISO changes.So you make those changed in the NR settings depending on what ISO you are using?Basically NR only relates to JPGs. It´s a balance between noise/"grain" and sharpness and detail.
That must take some time. I always try to use the lowest ISO I can. That is why I liked the T2 over other Fuji models. I can easily adjust the ISO at any time. I wouldn't want to stop and go into the menu system to increase or decrease the NR with every change to the ISO I might make.
