SONY a7 III a73 OVERHEATING issue
bogdiNES
Member
After using the Sony a7 III for half an hour taking a few dozen pictures (no videos) I've noticed the camera was a little bit too warm to the touch, so I decided to test the thermals of the camera by recording 4K video and monitor for overheating.
The overheating warning sign appears after approximately 12 minutes of recording 4K video and after 19 minutes and 55 seconds of recording, the camera shuts down because of overheating (minute 07:30 in the video).
I didn't heard anyoane having overheating problems with this camera until now, so I don't think this is widespread, this is just my experience with the camera.
Maybe others who have this camera want to test it for overheating in 4K video mode to see if this is a problem with the camera or just with my copy.
The room temperature was 23 °C / 73 °F
Auto Pwr OFF Temp. was set to Standard
For the test I was using full-frame recording 4K video 25P 100mbps
You could have cut out over 7 minutes of video and just showed the beginning and end. When I realized after a few seconds there was no sound, I skipped to the end.
I do have the A7riii and haven't heard anything about it overheating, but I usually don't take video for more than a few minutes at a time so for me it should be a non issue.
I abandoned Sony mirrorless cameras a long time ago due to their overheating issues while shooting video.
No overheating issues with Panasonic MFT cameras though.
this should be in the sony ff mirrorless forum.
it's typical for sony to release a milc with overly conservative heat warnings and behavior, then change the trigger points later in a firmware release.
for example, with the a9: https://www.dpreview.com/news/4228347869/new-sony-alpha-a9-firmware-fixes-overheating-warning
I could have cut out some parts from the video, but I wanted to show the whole video, so there's no reason to doubt it.
Everyone has different needs. This doesn't change the fact that this camera shouldn't have any overheating problems, but I think this is an isolated case.
any dimming of screen after 13 mins? about 20 mins thats really fine for me
thats why i wonder how they can make one 4k60fps without overheating issues in A7sIII or A7RIV etc
just made a 30 minute video 4k 30p. No overheating problem. No warning. room temperature 21 °. Active autofocus with face detection.
Jealous of you guys who have received your bodies already... for whatever reason they aren't shipping them until April 10th in the US.
Now recording, 4k 25p, 22°C. Display away from body, as in your video. Body just laying on a table.
10min: Body only slightly warm, hard to notice
20min: temperature behind display 36°C, the rest stays cool.
30min: temperature behind display 38°C, no sign of overheating.
Would suggest you send/bring back your camera - that's not normal for sure!
Edit: btw, I also had Auto PWR off at low, no problem at room temperature.
I would love to wait when I get it for a price close to yours :-)
(I paied $2.830 - €2300,-)
No screen dimming.
The problem is that even my a6300 in the same room temperature can record almost 45 minutes. This newer Sony cameras, from what I've read, should have solved the overheating problem or at least have a much improved recording time without overheating.
No screen dimming.
others seem fine though
try to do a few more tests to see if you got a bad copy
Could you please keep us up-to-date on your progress with this?
As soon as I have some news from Sony support, I will let everyone know.
Why not return the camera to where you bought it for an exchange? Wouldn't they be much quicker?
Have had no overheating with the 73 (nor the 7r2, the 72, the 7r3, the a7, the a6300...)
I am from Romania and I bought the camera from Germany, so, if I return it for an exchange, I would have to pay for shipping both ways and even if I do this, no one seems to have the camera in stock now or in the near future.
Depending on the response I will receive from Sony support, I will decide what to do.
Sorry, I don't believe you. The camera 'was a little bit warm to the touch' after shooting 24/36 pictures (a few dozen). Where was it warm?
Why haven't you linked to the whole video 19 minute video then? What use is the last seven minutes?
If you're posting the video as proof you need to show the whole thing, from start to finish.
Yeah, no me neither. Here's a link to an A7III test by Max Yureyev, who has done a lot of overheating tests with Sony cameras shooting video. He couldn't get it to overheat. Go to 14.11 in.
He shot it for an hour and a half and didn't even get the high temp. warning. Standard mode IBIS on. He says the camera wasn't hot to the touch.
