What ND filter do you recommend for 24-70GM
What’s the best nd filter to be used on the 24-70 gmaster lens?
thanks in advance for your input
There is no best in this case.
* What do you want to photograph?
* Do you need a 3 stop, 6 stop, 10 stop or even more stops ND filter?
For my self I use the Lee 100mm and Seven5 Little stopper (6 stops) and the Big stopper (10 stops) Als have a 3 stops voor the 100mm. Never use it.
I got the Gobe variable ND 2-8 and the build quality is excellent but the downside is that the outside filter thread is wider than 82mm which is to stop vignetting from the filter which seems reasonable except for the fact that the lens hood does not fit with it on.
I even went to the expense of getting a a screw on rubber lens hood but this caused vignetting so useless for 24mm field of view
