SkyEye
Active member
With Nikon announcing more VR lenses, and the long term forecast being for more, this might be a good time to discuss exactly how VR works. Is it some sort of motion dampening built in to the lens? Or is something else going on?
christian.
Do you have a link? I can't seem to find it on Nikon's USA site.
As I understand it, Accelerometer's in the camera's body feed data
to the lens. With that data the lense moves lens elements to
compensate for instablility (movement or shake).
If you really want to know how it works, the Nikon patents are very clear. If you go http://www.uspto.gov , click on "search patents", and then try the following, you'll understand quite well:...this might be a good time to discuss exactly how VR works.
--If the sensors were in the body, then you would have to upgrade your
D1s, D1x/hs and D100s for VR to work. The system works very well
and does not cause as big a drain on batteries as you might expect.
(I am speaking from experience with Canon's IS system, not the
Nikon VR system. But the tweo seem to be very close in technology
and functional ability)
Valliesto
'A hero is no braver than an ordinary man, but he is brave five
minutes longer.'
- R.W. Emerson
--Nikon VR only works on
F5, F100, N80, D100, D1, D1h, D1x
It will not work with the N90s or anything below the N80, so the
body does work into the equation somehow. Just not sure how?
Valliesto
minutes longer.'
- R.W. Emerson
chris robey
http://www.chris.robey.com
http://www.pbase.com/crobey/root&view=recent
