I've read on the forum about the Oly 12-50 f/3.5-6.3 ED EZ and most people seem to agree it's an ok lens if you can find it very cheap.
Looking at lenstip review, here if cam be seen that the MTF50 value is ~ 60 wide open.
Instead, for Canon EF 24-105 mm f/4L IS USM , presumably a very good lens, the MTF50 value is ~45
In both cases the value is given in lpmm (line pairs per mm, at the image plane).
I'm explaining it to myself like this: The ff sensor is ~35mm in heigt and the m43 sensor is ~17mm in height. Considering both lenses give a similar field of view at 24mm (canon) / 12mm (oly), but the m43 image is projected on a sensor that has half the height of the ff one, then the MTF50 result of the m43 system should be double the one of the FF system in order to obtain the same resolution (as far as this metric is concerned).
In this case, the Oly 12-40 F2.8 would match and slightly exceed the canon.
Is this correct ?
Is this correct ?
