DAVID MANZE
Hi guys,
I've been trying to link a couple of extension flash guns together using the camera's built in flash to trigger. The problem is one of the camera's pre-flashes which trigger the extension flashguns but don't synchronise with the shutter, the net result is you see the ext. flash through the viewfinder and get dark shots.
I have a optical trigger that I purchased when I shot Pentax which has switch for "red eye setting" with rotary control adjustable to ignore the pre-flashes and only triggers from the main one......unfortunately it doesn't seem to function....more dark frames.
I've by passed optical coupling from the camera and have dug out a cable and hot-shoe adapter which at least works. I've also ordered a radio controlled trigger and four slaves from China, so a wait of a few weeks!
However, it leaves me with the question, how many pre-flashes are there and is there no mode that just uses the main exposure flash without any pre-flashes at all?
I rarely use flash so thanks in advance!
Dave's clichés
Dave's clichés
