Good 10-15mm Full Frame
Deutsch
Forum Enthusiast
US
I had the Sigma 10-20, and it just never seemed fully sharp, especially toward corners with a little more distortion than I wanted. I bought this Nikon 10-24mm a couple years ago for my Nikon D7200 when I decided to get rid of the Sigma lens. This Nikon lens was a noticeable improved.
A few months ago I got a Nikon D750 full frame with the 24mm-120mm lens. But, there were some wide angle shots I needed and figured the Nikon 10-24mm DX lens would leave a lot of circles and major vignetting, but I decided to try it out. To my surprise, zooming between 10mm up to 15mm gave me full frame coverage. After 15mm you start to get the corner vignetting (since it's a DX lens and not FX). But, just what I needed.
I didn't have to buy a 14mm lens, which is what I was contemplating, since I now have that 10-15mm range to work with. This DX lens is an f/3.5-4.5, however, for the 10-15mm range, it stays between f/3.5-4. Point is, if you have this lens, and go full frame, you still have a good wide angle zoom.
Prove it. Attach actual full size examples.
Yes I use the lens down to 14mm and get full FX out of it, but the zoom range of use was supposed to say 15-24mm on that DX lens, vs the 10-15mm I listed. Thanks for catching that typo. That 10-15mm range was originally part of another sentence listing it as the non-useable FX range. I combined the two sentences and didn't correct.
That said, 14mm is what I find to be the minimum zoom and works great. It is essentially a 14mm f/4 lens, and I didn't need to go out and buy an FX one like I was planning to for the D750. So in correction, I have a decent 14-24mm FX zoom using this DX lens. Thanks again for the typo catch.
I tried this when I got my D750. Results are quite poor. Here's the 10-24 Nikkor at 15mm:
This lens was not designed to cover a 43mm diagonal so it's not the lens's fault.
Severe vignetting and poor sharpness on the FX frame. The 10-24 is a perfectly good DX lens and does not deserve this humiliation.
If you want ultrawide on an FX camera, you got to lay down the bread for an FX lens.
Leonard Migliore
Typo? You said 10-15 about four times.
