Absolutic
I discovered with A7RIII a new thing accidentally. As you know if you use Sony Brand Flash with Any Sony A7 or A9 or A6XXX camera, the HSS only works if flash is in the 90 degree position (oncamera). The moment you move the flash one degree into any direction, HSS cancels and you are back to 1/250 shutter speed.
This is only a problem with Sony brand flashes, 3d party flashes don't have such issues.
However, I discovered how to make the Sony brand flash work in HSS at ANY Angle - example with HVL43M
I have not tried if it works with any previous E camera, but it works with Sony A7RIII
