I just moved from a Sony A6000 to a D800, what do I need to know?
JosephmWood
Active member
Atlanta, US
Y’all have helped me a few times on this forum with some specific answers about lenses, but now I want to know what advice or tips you have for me.
Are there any good settings you use? Any tricks of the trade?
You are dealing with narrower depth of field and greater resolution. This will be far less forgiving of error.
Your technique will need to be better than ever. Nailing focus, keeping the camera steady.
And be sure to micro adjust your lenses.
Go to You-Tube, type in "D800 tips and tricks". LOT"S of good info there.
I have an A6300 and a D810 (among others). A pretty big user interface/adjustment capability difference in the two.
Both good cameras, just majorly different,
Mike
I’m going to be hitting up YouTube tomorrow for sure. Let me know if you have any videos that you like a lot!
Ken Rockwell has a complete guide of suggested setting, I use them on my D800. Happy shooting!
This have been said a lot of times - I still not quite do agree.
Why is it a given thing, that by having more resolution, you are changing the way, you view an image.
If you always have viewed at 100% - or always have printed at wall sizes, you are right - more resolution will show you smaller details - but my experience is, that this is not the normal way, viewing images are done.
The narrower depth of field (which can be discussed), will not be "less forgiving" because of the format sizes - shoot the two with conditions of same depth of field, and they will be equal "less forgiving".
Even better - be sure to micro adjust your lenses, if they need to be adjusted :-)
Out of my 10+ lenses, I have only one, that needs adjustments, and I'm still not sure, it's AF Fine tune, it needs - outdoor it's perfect without - indoor it's inconsistent even with.
