Did you repeat the calculations with the Distortion Correction off?Aha! These files did in fact get past my collaborator Quality Control (QC).I'm starting to think this is a lens correction that can not be turned off.So here are the 2D Fourier Transforms (2D FTs) of the black frames for a camera over each of it's 16 ISO settings from upper left by row to lower right (adjusted as usual to enhance patterns):
256x256 RGGB from the center of the image.
The first ISO setting with clear signal processing has a very unusual pattern.
I've never seen this dense grid before.
And rather than staying steady or increasing with ISO setting it fades, then comes and goes.
Very frustrating because (observed) read noise has a totally bizarre pattern.
Since FTs are reversible I tried the following crude test from row 2 column 4:
This concentric pattern looks like a lens correction like light falloff.
Not sure why the effect varies so much at different ISO settings; but this seems to be a start.
It is a fixed lens (not ILC) camera so they may have simply baked this in .
Regrettable since it's a DNG and they could simply put in the appropriate Opcode.
Exiftool confirms that Distortion Correction was On.
PDF of the user manual says it's a settable menu option.
So my contributor for this camera didn't fully follow the protocol and I didn't catch it until now.
What you see in you simulation is a standard Airy pattern created by the disk(s) and also a finer periodic pattern created by the periodic one in the FT. Does not look like vignetting correction to me, and certainly not like a distortion one.
