Thanks for the replies. You don’t have the same issue? There is no difference whether it is standard or high performance and under all light conditions.Do you have high-performance turned on?
http://fujifilm-dsc.com/en/manual/x-e3/menu_setup/power_management/index.html#power_management
Co-founder of the open-source LightZone Project: http://lightzoneproject.org/
Same issue regardless of DR setting. All 4 options of face detection / eye focus will cause the screen to flicker. Sounds like I may have a lemon then....I haven't seen any flickering using face detection with my X-E3.
The issue I recall hearing about was in conjunction with DR400 being set on camera – do you have DR on that setting?
This is my first Fuji. Can't say that im 100% satisfied with the build or the software but I love the jpegs. Im hoping this can be something that can be fixed in an update. I noticed that it flickers much less when it's not hunting for a face. That is when there is a face actually in the shot. It appears to me that it's making adjustments attempting to locate the face. If you turnnon the histogram it jumps in time with the screen flicker. Also when I switch to manual focus and back it stops.Suggest u check both still and movie mode. My first set has flickering issue in still mode when auto focus/eye priority is on. Changed a new set with no issue in still mode but just realised the screen starts to flicker in movie mode! Feeling let down with the QC of Fujifilm. Never had any issue with other cameras![]()
Thanks. Just processed the exchange with Amazon. Hope the new one doesn't have any issues when it arrives.Ok movie mode flickering issue resolved. Need to adjust shutter speed due to different lighting situation. Tested other bodies at the shop and all the same. AD also confirmed the flickering screen in still mode when auto focus/eye priority is on is a defect. Suggest you get your set change.
My replacement is "Out for delivery". Hope I have the same experience as you.Took my camera back and new one is perfect. My original one was from one of the first production runs and second one is a later run. No problems at all. Love the camera and size. Wish Fujifilm would come out with a small (pancake) zoom lens in the 24-70 range.
Great! U tried taking video? Does the screen flicker?Replacement camera arrived today and all is well. No flicker!
Nope nothing in video either. Really I would have never noticed it in video. Just tried it now to check and that's probably the last time the camera will be in video mode.Great! U tried taking video? Does the screen flicker?Replacement camera arrived today and all is well. No flicker!
