Does video wear out your sensor?
Innocentius
I read somewhere, long ago, that video 'hurts' your sensor, as that it wears out faster.
is this true?
(There is a debate going on about Canon not having the video-options others brands offer. There must be some thought on Canon-side wether or not to imåplement this features. Maybe this is one of the reasons)
is this true?
Well, we do know that sensors get hotter when shooting video. Thermal expansion and contraction of microscopic circuits will likely eventually lead to some failures on the sensor. There may be more dead pixels over time, or pixels that simply are not as "precise" as they might have been.
Having said the above, I do shoot small amounts of video and only experienced camera shutdown on a Sony Nex7. The other cameras 7DII and 5DIV don't shut down. I've never observed any noticeable image quality change so what little they may change over a few years of use is insignificant.
is this true?
Thanks man!
Good question. I wonder if more people can chip in with their ideas.
Thanks,
Armando
I used to wonder whether, as the mirror was up for longer periods, it was more likely to be exposed to dust. I don't worry about it any more.
I’m not aware of camcorders or video surveillance equipment wearing out from heavy use. Surveillance cameras run 24/7 for several years, and I’ve never heard of anyone ever complaining of degradation of the image over the years.
Sensors do experience mild heating during use, but my understanding is that this heating isn’t nearly enough to cause damage. I keep hearing about Sony cameras overheating while recording 4K, but I would guess that this is almost certainly from the logic processor chip (not the sensor) that encodes the video. I could be wrong.
why not email a few tv stations or even a network hq and ask if their on most of the time video cams suffer sensor failures ?
i would imagine that ooodles of videocams have had lots of long hours since the change to HD, but now some may be changing to 4k cams.
OR has there been a masters/phd thesis about or that includes this concept ?
me, i always worried more about shutter failure or dropping into water than sensor 'wear out' !
tom lowe (i think is name) wore out several 5d bodies doing a timelapse on the first ever 4kHD movie in 2012. he also used 4k camcorders for some work i believe.
TimeScapes-2012.
is this true?
TimeScapes-2012.
http://timescapes.org/4k/about_the_movie.aspx
is this true?
I don't know if videocamera-sensor are built using the same material and technology as photocamera-sensors are made.
My gut feeling says it doens;t, else everyone would start photograhping with a goPro Cam. but I can be wrong.
silicon is the very most common base material, but any material that can be 'grown' with very high purity and then 'doped/mixed' with another material which turns it FROM either a conductor (most usual) or insulator into a material that will 'release/generate' electrons when struck by energy known as 'photons' (light) can be used as a 'camera' sensor-a semiconductor-neither a normal conductor nor insulator-but can be made to conduct electrons in a controlled manner.
the efficiency of the electron release from photon bombardment is the Quantum Efficiency-QE-this can be changed/engineered but generally effects the spectrum of sensitivity to light - changes sensitivity to red,green,blue, so a specific QE is chosen for the specific purpose.
the QE is modified to get a 'workable' RGB sensitivity response similar to Human eyes-it could be very different if desired.
a pixel is a light sensitive receptor for photons.
lens and color filters guide and filter respectively the light hitting the pixel material.
CMOS - the most common sensor technology (but not only) is Complementary Metal Oxide Semiconductor.
the pc processor you are using is CMOS, as is nearly 100% of camera sensors and electronics within, and many other electronic things.
Answer: so NO there is no difference of a normal tv video sensor (although normally 1/3" or 2/3" size, some use 3 such sensors, 1 for each color for increased sensistivity) vs the camera sensors we use.
No the ONLY difference seems is the lens, many tv cams will have a 20-40x or even much greater zoom lens.
i recently noted a Canon tv cam used in Formula 1 race, it had a 20x zoom and was a 4kHD cam, on a tripod next to track and photographer was swinging it as cars past by @ 200mph, was ~2'x4' or so, likely 30lbs and cost $10,000+.
tv cams are a totally different breed from our small cams but same sensor tech.
TimeScapes-2012.
is this true?
