Ching-Kuang Shene
New member
- Messages
- 0
- Reaction score
- 0
The first modern SLR appeared in East Germany, the Zeiss Ikon Contax S, around 1949. This is the camera that started the M42x1 lens thread. Note that even though M42 is frequently referred to as Pentax screw mount, M42 is not the work of Pentax. In fact, Asahiflex appeared in 1952, which is Japan's first SLR; however, it did not use pentaprism and its thread size was M37x1.
Contax S: The first modern SLR that started the M42 lens thread mount
Zeiss Ikon in West Germany started making SLR in 1953. This is the Contaflex series of cameras. All cameras in this series used fixed lens (i.e., non-interchangeable). The first two in this series, Contaflex I and Contaflex II, accepted a front-mounting teleconverter. However, started with Contaflex III and Contaflex IV in 1956, all subsequent cameras in the series used a convertable design. If you played with large format lenses, you perhaps know what a convertable lens is.
The following is a Contaflex III of 1953.
Contaflex III (1956)
From Contaflex III and on, all cameras used Tessar 50mm 1:2.8 lens. The lever marked with a red dot is used to remove the front end of the Tessar lens.
Push the red dot lever inward followed by a twist to remove the front part of the Tessar. Note from the following image that there is a glass element in front of the aperture mechanism. Therefore, the "removable" component is just a single glass element. This front part is interchangeable.
There are three front lenses available as shown below. Note that the aperture mechanism and the glass element in front of it are fixed. This is the so-called convertable lens concept, because by swapping a portion of a lens we can produce multiple lenses. Note that a real convertable lens may allow both parts to be swapped.
From left to right: Pro-Tessar M 1:1, Pro-Tessar 35mm f/4, Tessar 50mm f/2.8 (on camera lens), and Pro-Tessar 85mm f/4
In his post, I tried the Pro-Tessar M 1:1 as shown in the left of the image below. The Pro-Tessar can reach 1:1 magnification.
Left: Pro-Tessar M 1:1 Right: Tessar 50mm 1:2.8
More than a year ago I bought a Contaflex lens and NEX adapter combo. The following shows the lens and the adapter, but the front end is a Pro-Tessar M 1:1.
Contaflex with Pro-Tessar M 1:1 on a Sony A7II
The maker of this lens and adapter combo was not very careful in choosing the lens, because the surface of the rear part of the lens has some cleaning mark that cannot be removed. By the way, this lens is very likely a lens salvaged from a Contaflex III, Contaflex IV or Contaflex Rapid. That is, this is a lens from the old series rather than a lens from a Super or a later model. The later lenses are supposed to be better.
The following image was taken with Pro-Tessar M 1:1 at nearly the minimum focus distance. It is clear that the vertical direction recorded approximately 22mm, which suggests that the magnification can be slightly higher than 1:1.
Magnification at nearly minimum focus distance
The following has some images. Refer to full size images to examine the quality of Pro-Tessar M 1:1. Note that, except for the first image, I did not use any PP.
Mellon - slightly adjusted using PS Level
Contrast is bit low but easy to correct
Peanut
Light Buld Label
Cherry
The Same Cherry from a Different Angle
I do not have any conclusions yet because it is the very beginning in shooting with these Pro-Tessar lenses. Please do keep in mind that all of these lenses appeared before 1959, the year Canon (Canonflex) and Nikon (Nikon F) released their first SLR professional cameras. Zeiss Ikon also made the Contarex (Bullseye or Cyclops) available, the first Zeiss Ikon interchangeable professional camera.
Canonflex: Canon's First SLR (1959)
Contarex Bullseye/Cyclops with a Contarex 135mm 1:2.8 -- Sorry, this lens is dirty. It is just for my own record.
You input and comments are most welcome.
CK
Peanut
Light Buld Label
Cherry
CK
