yodermk
Right now I have a Manfrotto pan-tilt head on a Manfrotto carbon-fiber tripod (don't remember model numbers). They are OK. The head was under $100 and the legs were about $350 (just for reference).
I had been thinking of getting an L plate for my Canon 5D Mark IV in order to put it on a tripod in portrait orientation, but looking into it, they are a bit more complex then I was expecting and I don't really want to have it permanently mounted on my camera. Apparently this p0 can tilt a full 90 degrees to get the camera in portrait mode. Maybe this would eliminate the need for the L? I realize that doesn't put the camera *quite* at the center of gravity, but it looks pretty sturdy and it shouldn't be far off. My current tripod legs allow the center pole to swivel out and go fully parallel to the ground, but that makes the camera go FAR out from the center of gravity and it doesn't inspire great confidence. Hasn't fallen yet, but I don't do that a lot and it's probably not as stable as should be.
Also I want something that will be good for shooting the solar eclipse next month. I just tested solar photography with my current setup and it seemed to work OK (holding a Canon 80D + 400mm f/5.6L + 2X TC III). Previously I had some trouble getting it to stay put pointing high in the sky but today's test seemed OK. Would this p0 be significantly more reliable with this kind of use?
First read about it from someone who used it with the MP-E 65mm supermacro lens, which I'm considering getting. Does it somewhat reduce the need for focusing rails?
Then there's the question of what tripod to put it on. My current legs might be all right, but I literally can't get the current head off them (I'm thinking it may have gotten a good bump in a suitcase and rammed something in tight). In any case I'll probably want a new set (should keep the current setup ready for video). One of the reviews on B&H says he uses it on Gitzo Mountaineer legs. Those look pretty awesome, though expensive. How about this? https://www.bhphotovideo.com/c/product/1034911-REG/gitzo_gt1542_mountaineer_series_1.html More expensive than I'd like to pay but maybe I need it to take my photography to the next level.
Also I think the biggest lens I am likely to get would be a 150-600mm zoom. Would love a 500 or 600 f/4 but I don't think that's gonna happen.
Haven't though too much about this kind of gear yet, so input would be helpful. Thanks!
