New firmware for Godox AD200 for Fuji
Etienne R. Werner
Leading Member
Den Haag, NL
Just found this on the Internet. Don't know exactly what it does but Fuji is listed. :-)
http://www.godox.com/EN/Download.html
I looked at that page that you linked to. I didn't see Fuji listed anywhere. Where did you see Fuji referenced?
It's also not clear to me how you would trigger it from a Fuji just yet as Godox has not released their Fuji wireless trigger. You can probably use other triggers (e.g. their X1T-N for Nikon) to trigger the flash in manual mode. Not sure if you'd get HSS that way.
Mike Dawson
Mike Dawson
This is in the description of the new firmware for the Ad200: It says compatible with Godox wireless Olympus/Panasonic X system and Fuji X system.
The new TT350F flash (when in master mode) can use it's build in transceiver to trigger all Godox flashes that are using the 2.4Ghz system. Additionally Godox is coming out with a separate trigger ( X1T-F) for the Fuji system.
As a bonus they seem to be bringing out a Led light head for the AD200.
Mike Dawson
OK. So it sounds like this is firmware needed for the day when Godox releases their Fuji flashes and triggers.
Mike Dawson
Does anyone know how to check the firmware version on an AD200? I have downloaded a new version but I am not sure it really took.
Should be in the manual. Go to the custom function screen.
