Some recent threads and messages have explored the notion of MTF. It appears to me that there exists a confusion in many people minds regarding what exactly is an MTF - the celebrated Modulation Transfer Function. For e.g., see the threads below that have many misleading statements, IMHO:
https://www.dpreview.com/forums/post/59557798
https://www.dpreview.com/forums/post/59563398
https://www.dpreview.com/forums/post/59563735
https://www.dpreview.com/forums/post/59619529
Before proceeding, I must say that the optics community is responsible for part of the confusion. By instituting terms such as MTF, which depends upon a certain notion of contrast , sometimes confusingly called modulation contrast (more on it below), and the use of another function called CTF, Contrast Transfer Function, (more on it below also), which is different from MTF. Though they share the words 'modulation' and 'contrast' respectively, and also use the same definition of measuring contrast!
What I write below comes from my memory as an undergrad in electrical engineering a long time ago, so please pardon me for some small technical mistakes or being not very rigorous due to a fact that I don't recall many details now as I haven't dealt with these things regularly for a long time. However, the following shall provide a right template or outline for understanding MTF.
Electrical System Theory:
- A linear shift invariant system (lets call it LSI) has an output that is related to input via a convolution. That is a very important theorem in linear systems.
- That convolution kernel is called impulse response. An LSI system is completely described by its impulse response.
- The collection of the ratio of the Fourier response of the output of an LSI system at each discrete frequency to the corresponding input frequency is called The Transfer Function.
- This transfer function can be shown to be the Fourier transform of the impulse response.
- Complex Exponential Signals are eigenfunctions of an LSI system. When they pass through a LSI the output is still a complex exponential signal but modified by an eigenvalue, which in general is a complex number. This collection of eigenvalues provides a certain transfer function.
- This transfer function can be shown to be the same as the Fourier transfer function mentioned above.
- For a very important class of LSI systems that have a real impulse response, the co-sinusoidal functions are also eigenfunctions.
- With this special LSI system a cosinusodial input yields a cosinusoidal output, possibly shifted in phase and attenuated. This system transforms a real-valued input to a real-valued output.
- The above is also related to the desire to having a linear operator involving the system as hermitian (or self adjoint) - though lets not get into the details of when hermitian and self adjoint are not the same things. That is only for mathematical curiosity. Also fans of Quantum Mechanics would get a kick out of this as such operators yield real eigenvalues that are observable. But lets not invite that delusional bunch
here. - The Fourier transfer function for LSI systems describes all of this.
- In Optics a transfer function is commonly used that relates the input and output via their modulation contrast.
- This transfer function, which is called the MTF, is real, as contrast by that definition is real, and so it is a ratio of reals.
- With the application of this transfer function a cosinusodial input yields a cosinusoidal output, possibly attenuated.
- It can be shown that this MTF is the magnitude part of the Fourier transfer function that we found in system theory above.
- The impulse response is now called Point Spread Function, PSF.
- In optics, typically not all impulse responses are called PSFs. Only those that produce observable outputs, and relates physical or real inputs and outputs.
- Hence, the importance of transfer functions that are hermitian and / or the importance of self adjoint operators.
- MTF is the response of the system to a cosinusoidal input.
- And, is the magnitude of the transfer function, which is the Fourier transform of the impulse response.
- Or equivalently, MTF is the ratio of output and input modulation contrast of a cosinusoid.
- A contrast transfer function or CTF is the response of the system to a square wave input, but otherwise measured with the same definition of contrast as the MTF.
- CTF yields values that are different from MTF, as can been seen easily by decomposing a square wave into Fourier components and applying MTF to each individually and adding up.
- There exists a relationship between MTF and CTF.
