Great shot - extraordinary detail.
If that's the full GFX frame, the Apo 'cron has better coverage than the Otus 55:I don't see strong vignetting. Does the lens cover the entire sensor or did you crop the image?
http://blog.kasson.com/the-last-word/otus-551-4-on-gfx/
Jim
Or resampling. The image is lot less impressive if it was cropping. Maybe the OP will let us know.The dimensions of the posted image as reported by Windows is 5206 x 3614. I think there was a little cropping involved.If that's the full GFX frame, the Apo 'cron has better coverage than the Otus 55:I don't see strong vignetting. Does the lens cover the entire sensor or did you crop the image?
The coverage is indeed impressive, and better than the Otus 55. Can't tell about corner smearing, since the corners aren't in focus. No color casting.Sorry. Yes it was cropped, as the scenario was a very poor (wide open, dark scenery in corners anyway) example of lens performance anyway.
Here's uncropped version:
