Who has lost their Sync terminal cap?
Canadianguy
Toronto/Ontario, CA
Was looking at my X-T2 the other day and noticed that I have lost my sync terminal cap - this happened to me on my X-T1 as well. I remember my Nikon D2x had the same issue - I was so happy when Nikon switched to the rubber flips instead of the screw in caps.
Anyone know where one can get replacements for cheap?
You can buy a Fuji cover kit from Amazon. Comes with hot shoe cover, terminal cover, and the bottom connection rubber cover (in case you use the battery grip). Not expensive.
First thing I discarded during film days when flash was necessary. Tens of thousands of exposures with no ill effects.
I nearly last mine on the first day. It wasn't screwed on tightly when I took it out of the box. I picked it up off the floor, screwed it back in tightly and it has been good for the last couple of weeks. Fingers crossed. I had to stop myself from using some crazy glue to keep it in place.
Thx!
Done!
Are these a universal item? I found some listed for Nikons and Fuji S3s, but not for the X-T series...
I think the Sync caps are universal(?); mine fell off the X-T2 at a very early stage but the dealer kindly mailed me a spare they had.
In month 2, it disappeared again so I bought 5x Nikon ones from Ebay for very little but now cover the new cap with tape to stop it happening again.
Maybe this is a Fuji design issue as I have never lost a cap from a previous camera make.
(nt)
who hasn't lost it you mean?
I lost mine twice in the first two weeks of using my new X-T2. I was getting annoyed at how easy they just came off. Finally, after buying the replacement package two times I finally got it put on tight and it has not come off since. It seems they need to screw in, not just push them to pop them in the hole.
I did not want to leave it off since I did not want the weather sealing to be compromised.
I lost it too from my XT-2..! And I didn't find the replacement yet anywhere... 😞.
Any suggestions anyone?
Thanks.
Thanks.
The now DISCONTINUED X-T2 CVR-XT2 kit comprised of a sync terminal, rubber seal for body terminal for grip, and a Hot-shoe cover. Some vendors might still carry these.
That kit has been replaced with the CVR-XT3 kit. This includes the same sync terminal cover, X-T2 body terminal cover, and hot-shoe cover, and adds an X-T3 body terminal cover, and a spare removable side-cover door. this kit is available from B&H and Amazon.
The same screw cover that is made for Nikon D200 bodies works for my X-T. Should work for yours too? Plentiful on eBay.
Same here. Since I screwed it back in though it hasn’t budged.
After losing more than a few, I taped one of the cheap amazon ones down with gaffers tape. I’ve got a similar problem with hotshoe covers.
I have... on every single camera I have owned (that had a cap) since 1982.
I bought a pack of 20 on ebay a while back. Glad I did. I think I've lost at least 5 of them. Just keep screwing a new one from the pack I got:)
I was hoping someone would find it. Thanks! :-)
I always remove the cap and replace it with Sugru. Never comes off, tidier and seals perfectly. It is easily removed when I sell the body when I put the original cap back.
