Hi Gavin,This is Gavin. I'm a newbie. Which one should I buy to start with?
May want to back up and figure out whether or not it's really a dSLR that's going to fit what/how you want to shoot and your budget, or whether a fixed-lens compact, mirrorless interchangeable lens, or dSLR are the best fit.This is Gavin. I'm a newbie. Which one should I buy to start with?
I totally agree!Your first dSLR ... should NOT, (repeat NOT), be a dSLR .... period
DSLR's were necessary 60+ years ago for wider and longer lenses.
BUT ... new technology has enabled MirrorLess to do the same thing .... and the same thing BETTER.
The question of the day! ;-)MirrorLess are easier/faster for "beginners" to learn on and eventually get better images with easy/fast ETTR for more optimum exposures with less noise and better IQ.
But ... what is your budget ???
Gee, with a question like that I wonder where this is headed? :-DAnd do you want "interchangeable" lenses ??? ... or can you accept a single fixed lens with equal or GREATER zoom range ???
Virtually every new camera shoots video. Basically it is a question of the needs of the OP, 1080p or 4k.Do you want the ability to do video ???
Unballanced with almost all lenses?There will be a mob that will tell you that mirrorless are the best thing since the sliced bread. Truth is that they are quite good but for the same endowment and performance you will pay between 25% and 100% more for it (depending on the brand). Also the lens lines are not so well developed (Micro Four Thirds being the most developed). Mirroless will some things better than dSLRs but also they will do some thing worse than dSLR. For the same sensor size the weight is not significantly lower and because some mirroless bodies have small form they will be unbalanced with almost all lenses.
Victor, I think for a beginner the real choice between mirrorless and DSLR is Optical View v. Live View. All the other gaps have been pretty much narrowed in the entry level to mid level cameras. We are not talking Nikon D4 v. Fuji T-2.First you should give us a budget and why you have chosen dSLR. What you want to use camera for?
As a beginner I would look at entry level cameras from all manufacturers (both dSLR and mirrorless). I would advise against a fixed lens camera as they are either horrific or expensive.
