Due to needs for cropping and other adjustments, editing the photos on PC has become part of my workflow in the past several years.
I recently bought DxO 11 (as the older version did not support my D7200 and FZ2500). I also use Nikon's NX-D and the free FastStone Viewer (it's an editor as well). Today I compared results between the three and wanted to share the results for anyone looking for such comparisons.
This first photo was shot at 200mm in 1.3x crop mode, giving FOV similar to 390mm at 15 mp resolution. 'Neutral' picture style. Vignette and distortion corrections turned on.
FastStone Image Viewer 6:
* Highlights -50
* Shadows 25
* Contrast 25
* Saturation 25
* Cropped to 2400 x 1600
Cropping in FS is the easiest. In addition to zoom, it also allows me to key in a window size.
Highlight, shadow, contrast and saturation settings are in one control window and it can remember the settings from last session.
DxO 11:
Automatically applies DxO lens softness, Chromatic aberration and Distortion corrections based on camera/lens profile, which is my default setting.
* Highlights -50
* Shadows 25
* Contrast 25
* Saturation 25
Did not apply 'Clear View'. Exported JPEG at 90% quality.
There are more options in DxO (for example, microcontrast in addition to contrast, vibrance in addition to saturation, etc. but I kept my editing to the same adjustments as in FS above)
DxO Optics Pro 11 Elite
Capture NX-D:
I don't think it applied any lens corrections
* Highlight protection 50
* Shadow protection 25
* Contrast 25
* Saturation 25
Cropping in NX-D was the most difficult. It doesn't show me the crop size as I am dragging the box. It took several tries.
Nikon Capture NX-D
This second photo was shot at 300mm in 1.3x crop mode, giving FOV similar to 585mn at 15 mp resolution. 'Neutral' picture style. Vignette and distortion corrections were turned on. Same place, same bird, but it turned to the other side.
* Highlights -50
* Shadows 25
* Contrast 25
* Saturation 25
* Sharpening 25
Applying sharpening is simple. There is only one parameter to select and I left it at default.
DxO 11:
* Highlights -50
* Shadows 25
* Contrast 25
* Saturation 25
* Unsharp mask, intensity = 100, Radius = 0.5, Threshold = 4 (all defaults) [more options = more power + more confusion!]
DxO Optics Pro 9 Elite
Capture NX-D:
* Contrast 25
* Saturation 25
* Unsharp Mask, intensity = 25, radius = 5 (all defaults)
Nikon Capture NX-D
Overall, when used with basic/similar settings, they all perform very similarly. May be, the FSIV is doing a bit more than what the selections show. I was surprised with its slightly increased the clarity, which is similar to applying DxO's Clear View at about 20% (or the Clarity slider in PSE 15).
FSIV's disadvantage is that it cannot apply any camera/lens corrections, nor can it process RAW images. If you get corrected images out of the camera, while retaining as much detail as possible, then FSIV may be one of the best free editors.
NX-D's advantage is that is has RAW processing capability, understands Nikon's NEF files better but the UI can frustrate sometimes. Best of all it is FREE!
DxO is probably the most powerful of these three and comes at a price. It has the ability to save full or partial presets with custom adjustments (I have one for birds, one for fireworks, etc.). It probably does the best camera/lens corrections. I like that it saves all settings in a sidecar file without needing a lot of storage (some folks like that PSE creates its own PSD files, but for me they are huge). It allows me to create 'virtual copy' of a file so that each one can be processed differently.
If I process the above two photos to my taste in DxO, the result is below...
Applied some additional adjustments on top of the first image above
Applied some additional adjustments on top of the second image above
Thanks.
'Knowledge is the only form of wealth that increases when shared' - unknown
My FZ2500 album: https://flic.kr/s/aHskQU7Thb
My D7200 album: https://flic.kr/s/aHskQjybAS
All my albums: https://www.flickr.com/photos/satya_a/albums
* Highlights -50
* Shadows 25
* Contrast 25
* Saturation 25
DxO 11:
* Highlights -50
* Shadows 25
* Contrast 25
* Saturation 25
Capture NX-D:
* Contrast 25
* Saturation 25
Nikon Capture NX-D
* Highlights -50
* Shadows 25
* Contrast 25
* Saturation 25
* Sharpening 25
DxO 11:
* Highlights -50
* Shadows 25
* Contrast 25
* Saturation 25
Capture NX-D:
* Contrast 25
* Saturation 25
Nikon Capture NX-D
Thanks.
