Both of there are shot in manual mode at 1/250 and f/3.2 with auto ISO and spot metering. Color temperature and tint aren't much different (3500 vs 3600 and -4 and -2). These were shot in continuous mode on a D3300 with a AF-S 35mm f1/8 prime lens. I know they aren't great photos, but am curious on the technical reason behind what's happening here.
What causes one to be so much warmer than the other or one to be so much colder than the other out of the camera? Should I be shooting differently? Thanks in advance!
My guess at the problem. There is fluorescent lighting in the room. The lights "flash" at 1/60 second thus mixing the daylight and the fluorescent. At 1/250 second shutter, sometime you pick up the lighting plus daylightand sometimes essentially only the daylight. You can see this in the relative brightness below the drawer and image left. This is further indicated by the fact that the door and room behind the child is essentially in daylight only and the drawers image right have a different lighting direction when the fluorescent fires.
You can confirm this easily. Take a series of pictures at 1/30 second ... they should all have essentially the same white balance. Then take a series of photographs at 1/250 second .... various images will have different white balance depending on how the room light happens to fire and the exact timing of the shutter curtain in relation to the fluorescent fire and if the image is horizontal or vertical.
Charles Darwin: "ignorance more frequently begets confidence than does knowledge."
tony
http://www.tphoto.ca
