I already wrote about this approach in another thread, but this is the only way to higher DR in a single exposure than current sensors.
It relies on ability to place more electronic circuits on the back of the sensor, thus increasing the speed at which the pixels can be read – see this Sony technology:
https://www.dpreview.com/news/56961...phone-sensor-that-can-shoot-1000-fps-at-1080p
In high-contrast cases, some pixels will be fully discharged (clipped highlights), and some – not discharged enough to measure (clipped shadows).
Time-domain acquisition is a paradigm – shift: measure not just the remaining photocell voltage, but also a TIME that it took for the cell to fully discharge, if it was less then exposure time. From there, you can easily calculate the highlight value that would be otherwise clipped.
If your shutter time was 1/100, and some pixels clipped at 1/500, some – at 1/423, 1/327, 1/248, etc., that will give you the would be value for that pixel. You can also wait longer for shadow pixels to register a minimal discharge, say, 1/64, 1/50, etc., to calculate shadows value.
It is easier and more precise to measure in time domain than in analog domain.
Another interesting approach is dual-resolution sensor.
Imagine a FF 36MP sensor, where the central area of a size of Micro 4/3 sensor is made of 4 pixels for each of FF pixels. In FF mode, these smaller pixels are binned together, and the whole sensor works like a 36MP FF sensor.
Then you can switch to M4/3 mode, use the central part of your lens image, where the lens is the sharpest, and get an equivalent of a 2X tele-converter!
This is to illustrate that sensor technology as a whole is not nearly at the dead end.
