leicaman
When using a remote release and the bracketing mode can I also use MUP and 3 second delay?
Thanks!
Thanks!
Sure why not. And set the electronic shutter option while you're at it.When using a remote release and the bracketing mode can I also use MUP and 3 second delay?
Thanks!
What I do is set mirror up mode on the left top dial, set Electronic front curtain in the menu (d5 in shooting menu), and use a remote. First press does metering (including pre-flash if you have flash enabled), raises the mirror and opens the shutter, then you wait until you are happy vibration has stopped, second press takes the photo 'electronically', ie it zeroes the sensor readout, waits 'shutter time', and closes the shutter. No need for the d4 delay mode if you are using a remote.In other words to get the benefit of EFCS and MUP I would indeed need to use the 3 second delay mode.... If you just release the shutter in MUP mode the D810 waits a full 30 seconds before releasing the shutter.
Is this possible on a D800 also?No need to set M-up.
Use the Custom Setting Menu/ shooting display and set to 3s delay.
On shutter press the mirror comes up waits 3 seconds then the shutter releases.
Yes, exposure delay and Mup are both available, and both of them raise the mirror before releasing the shutter. Do either of those and use a good tripod and you are good to go.Is this possible on a D800 also?No need to set M-up.
This is what I also do to get rid of vibration. Very straight forward.What I do is set mirror up mode on the left top dial, set Electronic front curtain in the menu (d5 in shooting menu), and use a remote. First press does metering (including pre-flash if you have flash enabled), raises the mirror and opens the shutter, then you wait until you are happy vibration has stopped, second press takes the photo 'electronically', ie it zeroes the sensor readout, waits 'shutter time', and closes the shutter. No need for the d4 delay mode if you are using a remote.
Bearing in mind that you lose electronic shutter if you do, unless you switch back out of LV before taking the shot. I do this as well if focus is tricky.This is what I also do to get rid of vibration. Very straight forward.What I do is set mirror up mode on the left top dial, set Electronic front curtain in the menu (d5 in shooting menu), and use a remote. First press does metering (including pre-flash if you have flash enabled), raises the mirror and opens the shutter, then you wait until you are happy vibration has stopped, second press takes the photo 'electronically', ie it zeroes the sensor readout, waits 'shutter time', and closes the shutter. No need for the d4 delay mode if you are using a remote.
The only other thing I add is if I'm going thru all the above, I'll probably be in Live View also. Might as well get the focus sharp while I'm at it.
THat is not true. EFC works as it should in LV. But you have to be in Mup release mode. Does not work on other release modes.Bearing in mind that you lose electronic shutter if you do, unless you switch back out of LV before taking the shot. I do this as well if focus is tricky.This is what I also do to get rid of vibration. Very straight forward.What I do is set mirror up mode on the left top dial, set Electronic front curtain in the menu (d5 in shooting menu), and use a remote. First press does metering (including pre-flash if you have flash enabled), raises the mirror and opens the shutter, then you wait until you are happy vibration has stopped, second press takes the photo 'electronically', ie it zeroes the sensor readout, waits 'shutter time', and closes the shutter. No need for the d4 delay mode if you are using a remote.
Why did Nikon disable Electronic front curtain in LV mode?
Nobody knows...
THat is not correct. Are you releasing the shutter twice? First for the mirror up/sensor state and the second for the actual exposure.In other words to get the benefit of EFCS and MUP I would indeed need to use the 3 second delay mode.... If you just release the shutter in MUP mode the D810 waits a full 30 seconds before releasing the shutter.
Firstly, you want to get rid of shutter vibration as well as mirror vibration. The best way to do this is with EFC (d5) set to on, LV, MuP and yes there is SOME logic to a 3 second delay. These are the steps the mirror, sensor and shutter are undertaking in this configuration when the shutter is released and you can see there is no mechanical vibration introduced by the camera whatsoever:When using a remote release and the bracketing mode can I also use MUP and 3 second delay?
Thanks!
I broadly concur with this method except that I prefer to use LV as it eliminates the mirror movement completely during a bracketing sequence. EFC works fine in LV as long as you are in Mup release mode.What I do is set mirror up mode on the left top dial, set Electronic front curtain in the menu (d5 in shooting menu), and use a remote. First press does metering (including pre-flash if you have flash enabled), raises the mirror and opens the shutter, then you wait until you are happy vibration has stopped, second press takes the photo 'electronically', ie it zeroes the sensor readout, waits 'shutter time', and closes the shutter. No need for the d4 delay mode if you are using a remote.In other words to get the benefit of EFCS and MUP I would indeed need to use the 3 second delay mode.... If you just release the shutter in MUP mode the D810 waits a full 30 seconds before releasing the shutter.
Ah yes you are correct. It's strange to click the remote twice and have absolutely no reaction from the camera, until you hear a faint click as the shutter closes five seconds after the second click. This is with a 5-second exposure of course.THat is not true. EFC works as it should in LV. But you have to be in Mup release mode. Does not work on other release modes.Bearing in mind that you lose electronic shutter if you do, unless you switch back out of LV before taking the shot. I do this as well if focus is tricky.This is what I also do to get rid of vibration. Very straight forward.What I do is set mirror up mode on the left top dial, set Electronic front curtain in the menu (d5 in shooting menu), and use a remote. First press does metering (including pre-flash if you have flash enabled), raises the mirror and opens the shutter, then you wait until you are happy vibration has stopped, second press takes the photo 'electronically', ie it zeroes the sensor readout, waits 'shutter time', and closes the shutter. No need for the d4 delay mode if you are using a remote.
Nobody knows...
This is the point at which the camera meters, so I presume it examines the data stream from the sensor which is currently going to the LV display to get metering info. The LV display goes black also so the LV video feed is switched off preparatory to waiting 'exposure delay'. Whether the camera gets enough metering info from the LV feed up to that point I don't know... it might do another check by zeroing and then reading the sensor... I doubt it though. If you set 'exposure delay' to zero then this would introduce an unexplained delay.2. First press of the shutter does nothing visible (mechanical) but probably changes the sensor state in some way.
Yes, that would be a far better implementation. Perhaps Nikon will release a firmware update introducing it.Ah yes you are correct. It's strange to click the remote twice and have absolutely no reaction from the camera, until you hear a faint click as the shutter closes five seconds after the second click. This is with a 5-second exposure of course.THat is not true. EFC works as it should in LV. But you have to be in Mup release mode. Does not work on other release modes.Bearing in mind that you lose electronic shutter if you do, unless you switch back out of LV before taking the shot. I do this as well if focus is tricky.This is what I also do to get rid of vibration. Very straight forward.What I do is set mirror up mode on the left top dial, set Electronic front curtain in the menu (d5 in shooting menu), and use a remote. First press does metering (including pre-flash if you have flash enabled), raises the mirror and opens the shutter, then you wait until you are happy vibration has stopped, second press takes the photo 'electronically', ie it zeroes the sensor readout, waits 'shutter time', and closes the shutter. No need for the d4 delay mode if you are using a remote.
Nobody knows...
I assume the first click does metering and nothing else except a piece of code that says "check if mirror up and shutter open... already up... do nothing... set flag to say ready for second click"
The second click presumably just zeroes the sensor and starts the exposure timer.
What Nikon didn't do which they could have, is allow EFC and shutter delay to be set, then without using mirror up mode, a single click could start the whole process and end up a few seconds later without bothering to click again. This could then be used in interval timer mode for example.
