fotobert
Leading Member
Just read it elsewhere
Cheers
Albert
Cheers
Albert
Maybe a hint about what we should be reading in the "Things we might find out at CP+ in 6 weeks " thread?Just read it elsewhere![]()
Cheers
Albert
There is already a huge thread over on the PentaxForums site.. with no information it appears to have decayed into silliness.Hi Miles,
that was exactly my first thought. We might discuss the name - K3 iii or K2
have a nice day
K-3IIs perhaps?We might discuss the name - K3 iii or K2
Am I alone in thinking that Pentax's model numbering is completely without any logic at all? Think:K-3IIs perhaps?We might discuss the name - K3 iii or K2
no -- the 's' only distinguished between lack of AA filter and having one. None of the K-3 series have an AA filter.K-3IIs perhaps?We might discuss the name - K3 iii or K2
Nikon and Canon are the same. Look at the 6d (FF low tier) vs the 7d (Crop sports) or the D5 (FF sports) D500 (FF sports) D5000 (Crop mid tier)Am I alone in thinking that Pentax's model numbering is completely without any logic at all? Think:
- K-3/K-30, suggestive of a relationship which isn't there.
- K-70 without a K-7.
- No distinctive model numbering system for FF - will be the K-2 be APS-C or FF?
That was the case with 5 series. In 3 series "s" might mean something else. What - we will find out in due coursethe 's' only distinguished between lack of AA filter and having one.
er there WAS a K7. Successor to the K10 and identical body and controls to the K5.Am I alone in thinking that Pentax's model numbering is completely without any logic at all? Think:K-3IIs perhaps?We might discuss the name - K3 iii or K2
The successor to the K-1 has no place to go but down, so it will be the K-2. That means the K-3 successor must be the K-4.that was exactly my first thought. We might discuss the name - K3 iii or K2
What about adding a 1 for the flagship APS-C like k11.k12. K13. K14 and so on.er there WAS a K7. Successor to the K10 and identical body and controls to the K5.Am I alone in thinking that Pentax's model numbering is completely without any logic at all? Think:K-3IIs perhaps?We might discuss the name - K3 iii or K2
"K-3 Super" would be my pick.
It's been odd having had a K10, K7, K5 and K5IIs (I skipped the K3) and now K1. K9 sounds like a dog, but they skipped the even numbers ...
K1 for full frame k1+for the flagship APS-C and k0+for the mirrorless.
It would only add confusion that would not benefit the company or the end user to re-use labeled in a different manner so close to product cycles.That was the case with 5 series. In 3 series "s" might mean something else. What - we will find out in due coursethe 's' only distinguished between lack of AA filter and having one.
I think they avoid it too, but Nikon did introduce a D4 before..Afaik the 4 means bad luck. I do not remember any version 4 of any japanese software.
As Pentax is the Master of odd numbers, everything might Happen. My guess is K-3 III.
Don't wrongly assume that if something confuses you it also necessarily confuses othersIt would only add confusion
Don't wrongly assume that if something doesn't confuse you, it also necessarily doesn't confuse others.Don't wrongly assume that if something confuses you it also necessarily confuses othersIt would only add confusion
If it's another iteration of the K-3, it will probably use the same sensor - which means that DR and high ISO will be unchanged.I think they avoid it too, but Nikon did introduce a D4 before..Afaik the 4 means bad luck. I do not remember any version 4 of any japanese software.
K-3 III 'Kay Three Three' sounds odd to me. 'Kay Three Mark Three' doesn't sound much better imo.
They can call it 'shamalamadingdongbluemoon' if they want to, as long as it performs better than the K-3 II in DR and high ISO and comes with a flip screen, as far as I'm concerned. :-D
Yep, brain fade.er there WAS a K7. Successor to the K10 and identical body and controls to the K5.
