DOF. Am I right in my assumption?
Mike MT
Member
Kalispell, MT, US
According to Jarrell, setting the lense to the widest view will give more dof. Using telephoto will decrease dof.
With this being the case, to get the best dof it makes sense then to set your camera 'closer' to the subject and widen the lense, than further away incorporating telephoto. But don't you need a higher f-stop to achieve good macro shots? The only way I can achieve higher f-stop is by using telephoto. Am I missing something? Do I need more light?
Thanks from a confused newbie S
M...
Yes and No. DOF depends on (1) focal length, (2) aperture, (3) subject-camera distance, and (4) the hidden diameter of the circle of confusion. If the same camera is being used, (4) can be considered as a constant. So, here goes the rules:
(a) If (1) and (2) are fixed, shorter subject-camera distance produces shallower DOF;
(b) If (1) and (3) are fixed, larger aperture (i.e., smaller x.y in Fx.y) produces shallower DOF;
(c) If (2) and (3) are fixed, longer focal length produces shallower DOF.
Thus, it is likely that a telephoto lens may produce a larger DOF than a wide angle does, because there are three involving factors.
To get the best DOF, one should use a lens of very short focal length, very small aperture, and larger subject-camera distance.
Because DOF is a function of 3 parameters, using a small f-stop on a telephoto may not be able to counter the impact of the focal length.
Take a look at the Depth of Field page of my 4500 user guide for more details.
CK
http://www.cs.mtu.edu/~shene/DigiCam
950/990/995/2500/4500 user guide
The short answer is that you cannot get more DOF by using wide angle and moving closer. As long as the subject size as seen on the CCD is the same, the DOF is roughly the same. I think?
Jim Tan
The shot is about 15" from subject. 2 (Aperture) and 3 (distance from camera to subject) are fixed. My Aperture is 10.3 and I'm zoomed (is that longer focal length?) to max on optical zoom. According to what you've said, that means I have 'less' dof. Ok, gotcha.
Now, I do have a Ring Lite, but attached to the camera it's only good for VERY close (camera to subject) shots. If you recommend I should use it for macro, how do I achieve a smaller aperture w/ the wider lense (because the camera is closer to the subject)?
If you addressed this in the Ring Light tutorial on your site, I apologize. Must've missed it.
Thanks again for the help!
M...
shallower DOF.
length.
more details.
CK
The SL-1 ring light has a weak intensity and may not be appropriate for day light macro shot. I normally used it in a very well-controlled environment. To get a small aperture, please try: set the ISO to 100 (rather than auto) and use long shutter speed. If noise does occur, consider the use of noise reduction. See the Sensitivity section of my 4500 guide for more details. I am currently testing a Samigon ring light, which is stronger than the SL-1. I will post my finding on my size when I complete this project.
No, I did not address this on my site.
CK
I read it and it did clear things up quite a bit. I'll try those settings.
project.
I look forward to seeing the results.
CK
Thanks again CK!
M...
No. You have discovered that you cannot have your cake and eat it too. Routine stuff. Everything is a trade-off. Good pics depend on good technical decisions on how to best depict your intended result. There is no magic setting that is always right or that gets you "everything". You're the photographer. You decide the most important bit to capture and use the appropriate settings. Even if the unimportant bits are lost.
Hey, if it was easy, anyone could do it! :)
-Frank
Michael Reichmann agrees with you, and that's good company to keep! ;-)
http://www.luminous-landscape.com/tutorials/dof2.shtml
Alan
http://www.pbase.com/abh
http://www.shutterfreaks.com/gallery/abh
Mike, sometimes it gets frustrating, don't it. Like Frank said, you can't have the proverbial cake and eat it. The main thing to remember is that dof is governed by the fstop you're using, i.e; f/2.8 = shallow dof and f/8=deeper dof AND it's governed by how far the subject is from the camera. So, if your camera is one foot away and you're shooting at f/5.6 you would get X dof. If you keep that same fstop and move the camera in to only 6 inches away, the dof gets narrower. In this example, you shot your dof down by moving in closer. The only recourse you have is to get more light on the subject so that you can change the fstop to an even smaller one, like f/8. That would give you deeper dof again. Remember though, that all the above is assuming that you do not change the focal length of the zoom, i.e; wide angle to telephoto. If you do that, then you've introduced the 3rd part of the equation.
It's something you just have to keep playing with. Set you up something like the batteries I used and take about 20 pictures at various settings and distances, but keep careful notes of what you changed. Pretty soon it'll all be second nature to you and when you look at a subject you'll know what to do.
Jarrell
M...
How to embed photos in your message!
http://forums.dpreview.com/forums/read.asp?forum=1007&message=4033727
Owner and user of 990 and 5700 and Photoshop. When looking at my pictures, never take it for granted I didn't enhance them.... :-)
Jarrell
Yep. Actual testing is the best way to learn about DOF. And... what better way than with immediate feedback from a digital camera. I must have gone through a zillion rolls of film and 5-10+ years before I started understanding DOF well enough to be able to "play by ear", as it were. With digital, that learning curve should be MUCH shorter! :)
-Frank
