Hi everyone,
I don't want to stimulate discussion on whether filters should or should not be used. I am new to digital photography but know enough that this is a contentious issue. What I do want to know is the following:
I presently have 2 lenses: 52mm and 58mm diameter. I am considering a third of 67mm. Rather than getting a polarizing filter for all three, I was planning on getting one of 67mm and using step-up rings for the other lenses.
1. Would this cause vignetting on the smaller lenses?
2. What if I shoot wide open at f/1.8, would that influence whether there would be vignetting in this setup?
3. One lens has an 18-55mm focal length. Would there be vignetting issues at the shorter focal lengths?
4. Does the fact that I am using a crop frame sensor (D5300) make vinetting less of an issue since it would be in the region that is outside of the captured area?
I am not considering getting a 52mm filter with step-down rings for the larger lenses since it seems that this might really cause either vignetting or blockage of some of the viewable area. Is that a correct assumption?
Thanks for the feedback. Cheers.
Mike
Mike
