"f4 & f5.6 on 1"-type cameras are equivalent to F11 and F15"
This has been an interesting thread, made more so by the quite graphic demonstration in Jeff's images that 1" sensor cameras need wide aperture lenses if they are to minimize the effects of diffraction.
It should also be born in mind that wide aperture lenses have problems with optical aberrations to a greater degree than small aperture designs, a fundamental difficulty that can only be defeated with complex, sometimes very complex, optical designs that cost scads of money to make. This is particularly a problem for wide range zoom lenses where aberration correction has to be maintained over the whole of the range. As a result, the lenses on modern super-bridge cameras are astonishingly complex devices. The lens on the RX10-III, as an example, is not only a seriously complicated physical assembly of glass types and shapes but is made hugely more complicated by the fact that the lens on its own would not be acceptable on any camera. Certain areas of aberration are not corrected in the lens, instead they are corrected with complex processor mathematics - the optical system is actually the lens plus the processor.
Returning to the main subject of image quality: it is a fact that as aperture grows smaller, diffraction increasingly degrades image quality but it is equally a fact that as aperture grows larger, lens aberrations increasingly degrade image quality and there will be a short compromise zone of aperture size only in which neither of these deleterious effects acts to push image quality below an acceptable level. It is only possible to widen this zone at the big aperture end by pouring money into a big funnel leading to a development department staffed with really, really clever people and sailing right along the bleeding edge of what is possible in glass, electro-mechanics, and processor technology to arrive at the kind of lenses we are now seeing on our 1" sensor cameras.
To widen the zone of usable aperture size at the small end is also possible because diffraction effects can be mathematically predicted and therefore, can also be corrected with complex mathematics - over a small range only.
These warring requirements for image quality maximisation in small sensor cameras, and the inescapable need for lots of money to push the opposing forces apart, are the reasons we are being asked to pay the best part of £1500 for an RX10-III and why we may have to pay £1700 for an RX10-IV.
This page discusses diffraction in a very informative way...
http://www.cambridgeincolour.com/tutorials/diffraction-photography.htm
The mathematical tools on the page reveal some fascinating insights - for example: to push the size of the diffraction disc, which is a measure of the fuzziness of the image of a fine point as it appears at the sensor, down to the size of the sensor pixels, the condition required to just produce images with full sensor resolution, needs f/2.0 on an RX100 at the shortest focal length of the lens. At all apertures smaller than that the image is degraded by diffraction. Of course, achieving this performance would also require a lens sufficiently aberration free that it could resolve the sensor pixels at f/2.0. It's difficult to justify big numbers of megapixels on camera with such sensors when this stuff is weighed into the argument.
Ed Form
Nice post, Ed. I enjoyed reading it. Thanks for the link, it almost makes diffraction issues easy to understand. The two little tools included are also excellent. I always suspected that 1" sensor cameras weren't completely free of diffraction issues at any F stop but it's nice to know my RX100M3 is totally pure at F1.8. Same can't be said for the RX10iii I'm afraid as wide open at wide-angle it just goes over the F2 diffraction free aperture for 1" sensors.
I don't think any amount of pixel jiggery-pokery in camera after image capture can reduce the effects of diffraction as the manufacturers would already employing it surely? We know they aren't because we can see the negative effects of diffraction in my experiment and on the DPR comparison tool.
The moral of the whole thread is not to stray above F8 to keep diffraction issues to an acceptable level and no further than F5.6 if you're a pixel peeper!
In the meantime I'll keep my RX10Iii on F4 most of the time and all of the time at 600mm then I know I'm getting the absolute maximum quality I can out of a very expensive camera. Maximum quality for bird photography is paramount. When you point a camera at a bird you are up against it from the word go and need all the help you can get.
David
it would have saved both Jeff and I a lot of work.
My set of test images = opportunity to verify or refute DPR test...?
And uber worthwhile wrt to my specific copy of lens.
Shooting test images rather quick (~10min) using 5sec timer;
File naming test images = 10min
Only additional test I've considered is the one
I wanted BEFORE I bought RX100-III =
RX10 vs. RX10-III, say, 24mm, 100mm, 200mm f2.8-f6.3,
directed at RX10 owners undecided about upgrading...
Wouldn't that test be "hidden" if added to this thread...?
Regardless, all responses were invaluable!!! regards jg
I wouldn't consider that test worth your time because all one needs to know about the lenses is one is 24-200 constant f2.8 while the other is 24-600 f2.4-4.
The reason I mention the A77ii is because it's AF is better and faster than the FZ1000, I shoot action and sports yet I find the RX10iii AF works for me most of the time so it's not a "for me" thing. I still have my A77ii with Tamron 70-200 USD for indoor basketball, a combo that will put both the FZ1000 and RX10iii to shame as far as AF in poorly lit gyms.
Quoted from DPR's Sony RX10-III review;
Then why is anything over, say f8, needed on 1" sensor Sony???!
Would dumping f9-f16 lighten up lenses further?
Or would it allow adding wider, say, f2, even f1.8, specifically
to RX10-IV, ie, trade weight of narrow fstops for wider fstops...?
Any optical engineers reading this?!
I'm certainly far from being knowledgeable concerning optical engineering, but it seems to me that limiting the aperture on the small end (higher aperture figures) would not make a lens smaller rather one would need to limit the aperture on the large end (lower aperture figures) and that would mean less light and a much slower lens and worse low light performance.
Thats a bold statement. You are saying DPR didnt do there job the right way?
quote from DPR:
Moving on to 400mm, the maximum focal length for the Panasonic FZ1000, we see a similar amount of detail between the Panasonic and Sony near the center of the image. Sharpness and resolution change for both throughout the frame, with the Sony showing a slightly iffy left side, and a better right side. Through most of the scene the two are practically neck and neck...
From what I see in the sample the RX10iii beats the Panasonic at 400mm despite what DPR is saying. From the comparative size of the images it also appears that at 400mm the FZ1000 has significantly less zoom than the RX10iii. Look for yourself.
From the same review
In all, it seems the RX10 III does offer a bit more than similar 1" bridge cameras from other manufacturers. It exceeds, or at least matches, the competition with respect to zoom range, while offering sharper images, and brighter apertures than all but Sony's own RX10 II. Importantly, sharpness performance appears to be maintained throughout the zoom range, from wide to tele, which cannot be said for any of the other cameras in this test. Feel free to explore through these images and post your own findings below.
And, I might add, the RX10iii blows the FZ1000 away at 600mm.
Tom
Look at the picture, not the pixels
Misuse of the ability to do 100% pixel peeping is the bane of digital photography.
huh??? was i talking about the far more expensive A77/Tamron combo???
again huh?? pls dont tell me you where expecting the FZ1000 as fast or faster than the A77 $$$$$$ Was i comparing to A77 combo??
Not for me, so who is right??
Just out of curiosity, would love to see my simple "road" test done with your (3~4x times the price!!) A77 combo. deal??
Hans
(ps: do you think a 4x $$$$ your A77/tamron combo ($9.000), could be faster than your combo?? See my point?? )
quote from DPR:
Despites?????, okeejjjjjjj,
I know there is a english expression : put your money where you mouth is...
SHOW me some of your shots and i will put mine there (if i have a likes..)for comparing.
TAKE some of mine.. and show YOURS better. oke?? Let the challenge start :-D
OMG i didnt know... my FZ only has EFL400?? and the RX10M3 has EFL600, thanx for pointing out.
EFL600 is more than EFL400, i know. The Zeiss is a holy lens, i know, but it all start with FOCUS.
(ps: what is yóur EFL500+ percentage???)
There's a reason I mention that combo, to prove to you that I know what fast AF is like. To prove to you that If the RX10iii AF has been fast enough for the action shots I take, that I haven't had to use my A77ii in months, then the RX10iii AF is good enough most of the time.
Wrong. I believe you are an FZ1000 owner who is trying to convince himself that it is a better camera for stills than the RX10iii. You noticed a very slight difference in AF speed in your brief tryout and, without fully testing it, convinced yourself that the RX10iii wasn't good enough because you didn't want to spend the $1500. Me I considered the $1500 I spent on the camera a bargain!!
I still have my A77ii with Tamron 70-200 USD for indoor basketball, a combo that will put both the FZ1000 and RX10iii to shame as far as AF tracking in poorly lit gyms.
No because I'm sure you would pick and choose what tests you did to prove your point. I could do the same thing with my RX10iii right now on this sunny day. You wouldn't be able to tell the difference between the A77ii and the RX10iii because they would both be so fast that the difference would be too small to discern.
Hans
Actually according to the DPR review of the A77ii the single point continuous AF speed, the mode I use, was as fast and accurate as any camera made including professional DSLRs costing 5-6 times as much.
"Continuous shooting with a single selected AF point, though, is right up there with the best of the competition, which means the a77 II can take on cameras well outside of its class and price range in this regard. That's pretty noteworthy, especially considering it can continuously AF at such a high burst speed (12fps)."
"The a77 II's 79-point AF system is very good. Continuous AF works really well in the vast majority of situations we tested the a77 II in. This camera is on par with the competition when it comes to quickly and accurately acquiring focus, no doubt in part to its dedicated phase-detect AF module that offers wide coverage across the frame. Face detect is also very effective.
I'd like to add, when it comes to video, something that is important to me, the RX10iii is far better than the FZ1000. For me, when I look at all the RX10iii can do, it is more a bargain than the FZ1000.
Tom
You are very confused...Those equivalencies are to get the same depth of field.
Is this incorrect?:
RX10-III f4 = f11 FF?
RX10-III f16 = f45 FF?
If latter correct, who needs f45 on RX10-III???!!!!
(some outlier macro shooter needing 2" to infinity DOF, maybe)
Therefore, if dropping, say, f10 (~f25 FF) to f16
loses some weight on RX10-III 24-600mm lens
that could then be traded for adding fstop at
wide end (say f2), that f2 would be employed
at times by, IMO, a huge number of shooters?
What I don't know is weight subtracted, weight added...
That where optics engineers reading this might respond...?
What I am ultimately proposing is an RX10-IV with
24-600mm f2-4 with f9 the highest fstop
There is this thing called the (sun) that you may need to stop down on or you don't get to take the picture. ND filters are great if you have one with you; if not, you are screwed unless you stop down.
JAW
You are very confused Jeff. Those equivalencies are to get the same depth of field. As the sensor size of a camera increases, your depth of field will decrease. It's physics. So theoretically, you can get the same depth of field with a larger sensor camera by stopping down the lens to that value.
Actually, your physics is not quite based in facts. As sensor size increases, the focal length of the lens must increase in order to maintain the same angle of view. It's this focal length increase that causes the depth of field to lessen.
Here are the formulas if anyone wants to dig deep into the math.
Notice that sensor size is nowhere in the formulas.
But the question is, would you? The answer is NO.
On most lenses, as you stop down past about f8 or so, you start getting diffraction effects. So you would be trading off DOF with softness.
Larger sensor cameras tend to gather more photons because of the increase in pixel area. You get better low light performance and decreased noise. Your tradeoff will be less DOF than a smaller sensor camera.
There is no perfect camera. Every camera has compromises. So pick the features you want, or have multiple cameras.
I have Friedman's book for the A65/A77. Found it very usefull. I had a lot of carry over knowledge from previous generations of Minolta/Sony cameras (e.g., the A200), but there are usually many new features with camera updates. It's good to have an expert explore the the new innovations and give helpful advice.
