https://shop.usa.canon.com/shop/en/catalog/imageprograf-pro-1000-professional-photo-inkjet-printerIs the Canon pro 1000 not capable of making 16x20 prints? If this is correct, whats the purpose of a 17" printer? What about 8x10 and 11x14 prints? What exactly is it capable of printing? Thanks!
https://shop.usa.canon.com/shop/en/catalog/imageprograf-pro-1000-professional-photo-inkjet-printerI wonder how long it will take them to update their online specs that decision makers use to select products.
Pat
Your questions reflect the market it's aimed at.2:3 to match their cameras instead of matching standard offset printer plate sizes - brilliant of them.
Because the firmware allows for custom sizes, it'll make whatever you want. The frame in this picture, well, not a frame in the traditional sense, is 12X18. I use 13X19 paper and when I print it, I make it slightly larger than 12X18. I use a spray adhesive and lay the picture on the frame. Then I trim the bit of overhang with a razor blade.
Sometimes you have to play with the image a bit to get it to fit properly, but it's pretty rare that I can't get one to fit a custom size. I just made a 10X10 of the same sort for a customer. This one was printed on a Canon Pro 100, but I now have an Epson P800 and just printed more for the same type frame of the same size.
David
When one engine fails on a twin-engine airplane, you always have enough power left to get you to the scene of the crash.'
Viewbug: https://www.viewbug.com/member/David_Pavlich
The on-line report on the current firmware upgrade 2.1 (indicates the following:You mentioned wanting a unit that supports a printable area of 17 x 25.5 inches. However, for paper sizes other than Letter or Legal, the maximum printable area for the imagePROGRAF PRO-1000 is 16.73 x 21.69 inches (paper size of 17" x 22"). Consequently, this will be the maximum printable area for an image to show.
This gives me some confidence that I would be able to produce a (pretty much) 17-inch wide 2:3 image on the printer. What puzzles me is that this printer was not introduced with this image size - it seems somewhat important.[Ver 1.0]
The maximum printable height of custom paper size will be lengthened to 25.5-inch (647.70mm) with specifying in the printer driver.
I use Moab Desert Varnish. Adorama sells it.David, what do you use to coat your print with?
David
I've used that and Hahnemuhle's version, but never considered them tough enough to withstand handling and being directly exposed to the environment.I use Moab Desert Varnish. Adorama sells it.David, what do you use to coat your print with?
David
David
Interesting, would make me a bit nervous, though.I sell my prints and handle them as little as possible. What the customer does with them is out of my control. I let them know at the time of purchase that the prints have been coated to give some protection against UV light, but also tell them that it's not a coating that will stop the print from being scratched.
So far, I haven't had a problem reported to me.
I'm just getting sick of looking at my images through highly reflective glass (and the AR stuff is insanely expensive) so have been trying alternatives like canvas. But if I could find a really good durable economical coating that would be really nice. I've been tempted by epoxy but it's both expensive, a bit messy and relatively (compared to a spray) labor intensive. I was just hoping you'd found something that matched what I'm wanting.I also sell prints in conventional frames, but some like the open look that the above mounting gives.
I've made a few 16X21s as well now that I have the P800.
David
That would seem to be a very low-hanging fruit for their firmware team..And why not permit it to print panoramas at pretty much any length 17 inches high?
13x19 and 13 x 25.5Is the Canon pro 1000 not capable of making 16x20 prints? If this is correct, whats the purpose of a 17" printer? What about 8x10 and 11x14 prints? What exactly is it capable of printing? Thanks!
If you would just looking it up would see that it is not a 17" printers. Since you obviously HATE this printer i would suggest that you get you yourself another printer that will meet your needs.
