Brownie1010
Well-known member
Hi, I have recently added the Sigma MC-11 adapter and 150-600mm Contemporary so that I can retire (sell) my Panasonic FZ-1000. Have been using my A6000 for general use, and in an underwater housing (Meike) for taking shots in the surf, but have wanted for some time to replace the FZ-1000 for beach shooting. I have never trusted the FZ-1000, despite its specs, after a mammoth battle to get the lens replaced due to focussing issues soon after I bought it (refer gallery and posts in the Panasonic forum). Now, I just love the A6000 and am determined not go back to a big DSLR, even for sports photography!
So, these shots are selected from about 450 shots taken one afternoon at a local beach, on its second outing, so still getting used to it. I was shooting my son and his mates in the surf, using a monopod, when suddenly some acrobatic planes appeared, so did some impromptu handheld ones. The later shots of the boys, and a group of people taking photos of their daughter were also handheld.
Posting these to show that even without the better AF system of the A6300/6500 (which I will upgrade to in due course) the results are pretty good. All the surfing and plane shots were taken as part of mid-speed bursts, with high "keeper" rates, probably 9 out of 10 (or better). I find that using the lower burst rate allows me to keep shooting (some rides can go for 15 seconds, and buffer overrun is one reason is why I need to upgrade, better PDAF-based AF being the other).
All shots have been exported as sRGB JPEGs (1400 on the long side, as per the ZackieDawg standard) with no sharpening, no cropping, no exposure adjustment ... no nothing.
Settings were Shutter-priority at 1/2000, Auto ISO, focus AFC-C (but not sure what the camera actually does through the adapter interface, probably AF-S, but the camera EVF displays Lock-on AF and a green indicator - need to research more).
Focal length in these images varies, but generally 300 to 550mm on the Sigma (so apply 1.5 crop factor for 35mm equivalent). Tried to avoid shooting at 600mm as testing shows the lens softens at the end of its range. And at that FL, its too hard keeping the surfers in frame through a burst, especially if they launch into an aerial (cropping off your son's head in his most soaring moment is viewed with some disdain at post-mortem ...).
Image 1a : 1/2000 f5.6 ISO 250 and 302mm (so 453mm 35mm equivalent). All good, in nice sequence.
Image 1b: Next frame in sequence, shows change in subject at the Mid frame rate ... risks missing peak action.
Image 2: 1/2000 freezes the spray, can go to 1/1600 but no lower ... Aussie beach - lack of light not an issue!
Image 3: Problem - focus has shifted to the broken wave in front despite using the 10m+ focus switch on the Sigma (because the wave is actually 50m or so away). Stopping focus shifts to foreground is a big problem when the shooting angle can't be elevated, which would also reduces the impact of the shot). Maybe this is something I can adjust if I get the the USB dock, by limiting the refocussing "slew rate". Future research.
Image 4: not that interesting, except that even with white foam, white shirt, white board ... the focus system works ... but maybe that's why
Image 5: I use a small Flexible centre spot for focus area - it can get busy out there ... with the spot adjusted upwards above the horizontal centreline (to bias it away from broken wave focussing, the problem seen in Image 3.
Image 6: not that interesting, just wish my son would adopt better hand positions - he'll never win a title without attention to these details!
Image 7: the acrobatic planes appear, I lift the monopod and shoot handheld. Not easy getting PIF even coming at you. Is planes-in-flight even a sensible acronym? Maybe ZackieDawg can advise
Image 8: they get closer, maybe even start to get interesting ...
Image 9: but it's not all good, start of a burst, and focus not achieved.
Image 10: but two frames later it's OK. Keeper rate swinging the lens around at the sky is high, but lower than monopod.
Image 11: 1/2000, f6.3, ISO 250, 388mm, monopod. Light is starting to fade.
Image 12: 1/2000 f5.6, ISO 160, 252mm, handheld. I like the subject isolation, no bokeh though ... damn.
Image 13: 1/2000, f5.0, ISO 320, 157mm, handheld. Spotted a photographer taking family shots. Very cute.
Image 14: 1/2000, f5.0, ISO 800, 157mm, handheld. Time to go home.
That's it. Longest post in my history, hope it uploads. [Edit: It did, and now see that the camera settings are overlaid by the site itself ... sigh.] All taken with the shutter-priority and auto ISO settings adopted at the outset, and nothing changed throughout. Hard enough keeping things in frame for me without going all "manual" ...
Absolutely looking for C&C here. I am pretty happy with the Sigma lens+adapter combination, look forward to learning how to use it better, with an eventual upgrade to a A6300/6500/6700 on the cards. Have now pretty well decided the fall-back option of buying a Canon body just for action photography is unwarranted.
Cheers, Brownie.
Cheers, Brownie.
