M 240 with external flash/studio lights
FZBL
Member
I noted an important (atleast for me) feature-lack of PC sync socket.
There is a workround but still not too convenient.
Whats your adivice and also what is your set up to tackle any challange?
Thanks.
Didn't understand the question. You need to know about alternatives to a flash trigger?
Thanks.
Check eBay for cheap triggers. Most will work fine.
If you gotta use a cord for some reason, there are adapters available that slide into the hot shoe and have a PC sync outlet.
www.rodriguezahr.com
Thanks.
Sorry about not clear enough. Actually I want to use EVF also. After some thought,it is possible to use most long lenses with external flash by adding multi function handgrip.
Its not a problem with standard 50mm and wider lenses.
