I tried to test for focus shift. Lens is 24-105mm F4 DG OS HSM | A, 1 month old. Camera is sd Quattro running firmware v1.03.
1. Set
manual focus to a given point on slanted ruler, using EVF and focus peaking.
2. Take a shot at F4 and one at F8, and others in between, without changing the focus setting.
3. Inspect images for evidence of focus shift.
I chose a focal length of about 50mm, and used a focus square to the left of center. In manual focus mode, this is where the magnifier looks. Camera was on a tripod, about 4 ft from the focus point. While I was writing this post, the cat moved into my test setup and fell asleep. So should we all...
When looking at the test images I discovered that focus is a little off even at max aperture: Focusing at a point on the slanted ruler does not give me a symmetrical focus fade out around this chosen point, but the point of focus is a little bit further away than this. Maybe it is time to get out the USB dock. On the other hand, this is
not the same as the focusing I did. So, this quirk bothers me. I'm using the focus magnifier and focusing manually, yet the images show a different focus point! I repeated my attempts to manually focus properly, watching the focus peaking for symmetry around the focus point, and still got the same result. Something fishy here. I am not likely to see this using a fully manual lens, at least this is my guess at this point.
Moving on, I inspected the images and could not find anything to show a definite change in focus as F-stop was changed.
Conclusion is that even though the lens is set to manual focus with image stabilization off, something is happening that is beyond my control, and this changes the focus point.
Tom Schum
Every day a new image.
